can i put 33's on my tacoma
Discussion in 'Wheels & Tires' started by mfkokoska, Feb 25, 2011.
  1. Feb 25, 2011 at 3:47 PM
    mfkokoska
    mfkokoska [OP] Active Member
    matt
    sydney ns canada
    i have a 2003 tacoma trd with a 2.5 lift. can i put 285/75/r16(33's) on?
  2. Feb 25, 2011 at 3:51 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    You can do many things.
  3. Feb 25, 2011 at 3:51 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Kyb Shocks... for now
    do you go wheeling? Because sometimes what will fit and what will be wheelable are 2 different things
  4. Feb 25, 2011 at 4:03 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I can wheel just fine with 33x12.5's you just need to do some cutting :D
  5. Feb 25, 2011 at 4:05 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    minor trimming will be necessary look up "the pinch weld mod". depends on the offset and backspacing of the rims as well. im currently running 285/75R16s on my '02 with 2.5"
  6. Feb 25, 2011 at 4:14 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    you should probably say specifically how much lift you're running to use 33s
  7. Feb 25, 2011 at 6:47 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    just saying, search feature! but it'll fit with trimming
  8. Feb 25, 2011 at 9:12 PM
    Flash2408
    Flash2408 Well-Known Member
    Justin
    Chattanooga
    99 reg cab 4x4 green
    rough country lift
    I run 33x12.50's with bout 2.5 lift
  9. Feb 25, 2011 at 9:17 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    same here
  10. Feb 25, 2011 at 9:19 PM
    toothaker1219
    toothaker1219 Well-Known Member
    Google the question first... It has many comments and threads about this already- TTORA, Pirate, TW, TN, etc.
