Can I replace stock fog lights with 2x2 LED squares?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chucky836, May 21, 2013.
  1. May 21, 2013 at 7:13 PM
    Chucky836
    Chucky836 [OP] Active Member
    Charles
    Houston, TX
    '13 PreRunner TX Edition
    None yet.
    So I really think it would look sweet if I replaced the stock circle fog lights with two 2x2 LED cube lights. Can someone maybe point me in the right direction on how to do this?
    Change these:
    To these (or something similar):
  2. May 21, 2013 at 8:39 PM
    eric3187
    eric3187 Well-Known Member
    remove round light... mark a square, cut a square, and then just look for a sturdy place to attach. drill a hole and bolt 'er up.
    while i dont have a factory bumper, i replaced the fog lights with Rigid duallys with the diffused lense, great for a fog light and a wide spread, but i would look into a flood pattern if i did it again. (incase you had to choose)
