Can I run 285's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Range 44, Apr 26, 2011.
  1. Apr 26, 2011 at 6:26 AM
    Range 44
    Range 44 [OP] Well-Known Member
    Georgia
    2008 FJ TTE
    Looking at putting eibach's on with billies at .85, I have the TSB done and will be adding a 1.5 TSB AAL. I have the factory Fj 17" wheels. Can I run 285/70 17 with this set up? Will I need UCA's? Does anyone know the backspacing of this wheel? Thanks
  2. Apr 26, 2011 at 6:29 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Nope, not without major rubbing
  3. Apr 26, 2011 at 6:32 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Stock FJ Backspacing is 5.5" You will wheel spacers, and then you'll have to cut a bunch of plastic. Then you'll probably still rub on the cab mount.
    Andy Lurry's right, this topic has been covered about 1000 times.
  4. Apr 26, 2011 at 6:36 AM
    Range 44
    Georgia
    2008 FJ TTE
    Yeah, sorry I always try searching first but sometimes you find 70% of the answer you really need. So I guess you have to go a full 3" for 285's
  5. Apr 26, 2011 at 6:37 AM
    KPT
    09 Prerunner
    Nope, but you do need wheel spacers.
