Can I run extended travel rear shocks with just leaf hangers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iTz IAN, Jan 7, 2013.
  1. Jan 7, 2013 at 2:13 AM
    iTz IAN
    iTz IAN [OP] Well-Known Member
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    I would get Bilstein 5100s with leaf hangers and keep the stock leaf springs, and modifications needed?
    what exact size 5100s could I run, also hangers to get the most rear travel without cutting or drilling
  2. Jan 8, 2013 at 6:49 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
  3. Jan 8, 2013 at 7:03 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    im not certain what a leaf hanger is?
  4. Jan 8, 2013 at 7:09 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Shackles?
  5. Jan 8, 2013 at 8:40 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    yeee hahaha my bad
  6. Jan 8, 2013 at 8:46 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    These shocks: With a shackle lift or block.
  7. Jan 8, 2013 at 9:04 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    why is the mount different, instead of the threaded shaft theres a mounting point welded
  8. Jan 8, 2013 at 9:09 PM
    Redneck92
    Concord, NC
    opps thought this was 1st gen section so diregard what I said
  9. Jan 8, 2013 at 9:16 PM
    Redneck92
    Concord, NC
    They do make stock length 5100s if you didnt want to lift it. Whats your intended purpose of your truck?
  10. Jan 8, 2013 at 9:38 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    prerunning and trails
    i was hoping to get more travel without leaf springs
  11. Jan 8, 2013 at 9:44 PM
    Redneck92
    Concord, NC
    That rules out aal because they do add lift but stiffen the springs, blocks are pointless in your case. If it were a 1st gen I'd say throw some shackles on it because they will add some travel. But ultimately you'd be better off to get new leafs unless you feel like fabing a shackle flip.
  12. Jan 8, 2013 at 9:45 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    You would probably like the wheelers or the icon 3 leaf progressive addALeaf it's a nice ride and somewhat affordable and then get some 5100 to accommodate the lift this will cause about 400 bucks I'm just estimating here with the price.
  13. Jan 8, 2013 at 9:53 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
  14. Jan 15, 2013 at 3:40 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
  15. Jan 15, 2013 at 3:45 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    what is the standard length of the 5100's and what is the extended length
    with just shackles it seems like the shaft would bottom out?
  16. Jan 15, 2013 at 3:55 PM
    Redneck92
    Concord, NC
    I would bother with shackles on a 2nd gen unless it's a shackle flip. I'd run wheelers progressive rate aal or go to a junkyard and grab a few sets of leaves and make a bastard pack as in the link. If you have the time to do it the second option is cheaper.
  17. Jan 15, 2013 at 4:02 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    what does a shackle flip do ?
    any links
  18. Mar 6, 2013 at 4:02 AM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
  19. Mar 6, 2013 at 7:29 PM
    Redneck92
    Concord, NC
