Can I tow a 4250 lb Airstream Camper with my Tacoma V6?
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Feb 28, 2015.
  1. Feb 28, 2015 at 9:39 AM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    I have a 2004 Tacoma, 3.4, 4x4. No towing package that I know of but I do have a ball and hitch rated at the appropriate amount to haul something this big.
    I am contemplating buying a 1967 Airstream 26' Overlander. I looked up the curb weight and it says 4250 lbs dry weight. It's halfway gutted so it probably weighs a little less than that.
    I would be towing it about 90 miles one way. Can my Tacoma handle it?
  2. Feb 28, 2015 at 9:45 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    They are rated at 5000lbs towing capacity so you shouldn't have a problem.
  3. Feb 28, 2015 at 9:53 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    that said, you need to add the weight of gear and stuff you put in it too so you are right at the limits of what you can pull but I don't think you have near enough stopping power to pull that so it will be pushing you every time you try to stop.
    can you? yes
    should you? probably not
    if you do will it be a problem? only if you need to stop quickly, you wont be able to
    if you do decide to tow that with your truck make damn sure you add brakes for the trailer to help it stop so it doesn't jackknife your truck if someone pulls out in front of you at the last minute and you have to hit the brakes
  4. Feb 28, 2015 at 9:54 AM
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    I have a 1977 23 foot Airstream and have not tried to pull it with my 2015 TRD 4.0 and automatic. Check your weights, our 23 footer weighs 6240 loaded and ready for the road, full of water, waste tanks empty, this is weight across scales. The 1977's were known to be heavy as tow vehicles were usually 3/4 ton Suburbans and pickup trucks. We tow it with a Dodge 2500 4x4 diesel and it barely knows it back there. A 26 footer wouid be guite a long load for a Tacoma if it started to sway. You didn't mention what transmission you have, but not sure the 6 speed would be best, and an automatic would need additional cooling. I would think twice befor trying it.
  5. Feb 28, 2015 at 10:12 AM
    veg hed
    Utah
    I have a 5 speed. I only need to tow it to my house where I can work on it as a project. So it won't be something I tow everyday.
  6. Feb 28, 2015 at 10:17 AM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    if your trip doesnt have any big long hills you will be fine, but make sure it has trailer brakes and get a brake controller..
  7. Feb 28, 2015 at 10:23 AM
    keakar
    karl
    louisiana
    you should be fine then, just treat it like you have no brakes at all (because in reality that's pretty much true when pulling that much weight in your truck)
    it might be good to have someone drive ahead of you so you can follow them by a few car lengths behind so if shit happens and you do have to stop quickly and slide into someone, its your buddy and not someone who wants to sue you.
  8. Feb 28, 2015 at 10:33 AM
    oldracer
    oldracer Well-Known Member
    Definitely, make sure the trailer brakes are working; and you have the proper brake controller, installed in your truck.
    Sure the Tacoma can move the trailer; but can you stop it in an emergency. I see you may be posting from NC; will you be towing the trailer in the mountains?
    I have towed many trailers, hauling heavy equipment; and recreational trailers hauling just about anything. There is no need to do any white knuckle driving; especially with the laws and lawyers of today.
    oldracer
  9. Feb 28, 2015 at 10:37 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Like the others say, just take it easy and expect to brake sooner. If you have any doubts about it, go rent a uhaul pickup for the day.
