Can I tow this camper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scorn, Dec 5, 2012.
  1. Dec 5, 2012 at 5:27 AM
    Scorn
    Scorn [OP] Well-Known Member
    Indiana
    TRS Sport Dbl Cab
    Here are the specs and I do have the tow package.
    Length29'0"Width8'0"Height8'8"Interior Height6'6"Hitch Weight481 lbsDry Weight4,308 lbsCargo Weight2,698 lbsFresh Water Capacity36 galsGrey Water Capacity60 galsBlack Water Capacity30 galsFurnace BTU30,000Sleeps6Tire SizeST205/75R14/CSlides1Interior ColorearthVIN2471033
  2. Dec 5, 2012 at 5:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's a lot of trailer for the Tacoma. It will tow it if properly equipped with a good brake controller and a W/D hitch but I don't think I'd attempt it personally.
  3. Dec 5, 2012 at 5:41 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    ^I'm with this guy. Dry and empty-It's doable. Wet and/or some cargo- It'll be a challenge. Wet and fully loaded - Exceeds the rated capacity out the Tacoma.
    And doable doesn't mean easy. I'd go with a smaller trailer or a bigger truck, depending on which you are looking at buying...
  4. Dec 5, 2012 at 6:04 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Pulling isn't the issue.. It's stopping it.
  5. Dec 5, 2012 at 6:08 AM
    Scorn
    Indiana
    TRS Sport Dbl Cab
    Thanks for the warning, it does make me wonder though, as many on this forum are towing heavier campers with the same truck.
    Is it the length or the weight or both?
  6. Dec 5, 2012 at 6:09 AM
    Spruced UP
    Spruced UP Well-Known Member
    Eric
    Jacksonville, FL
    2013 DCLB PreRunner TRD Sport, Spruce Mica
    Pic of the camper?
    I agree with the other responses.
  7. Dec 5, 2012 at 6:09 AM
    IndianTaco
    IndianTaco Well-Known Member
    Thats alot of camper... i wouldn't try it
  8. Dec 5, 2012 at 6:12 AM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    The length can mostly be controlled by a good anti sway hitch. The weight of that at that length is the main issue.
  9. Dec 5, 2012 at 6:13 AM
    Pugga
    Massachusetts
    The overall size. A 29' travel trailer is a big camper. The weight is one thing, it's high but is within the truck's limits with an empty truck and a dry/empty trailer. You also have the huge profile of the camper, lots of wind resistance and side surface area to get that truck swinging. With good swap control, brake controller and a W/D hitch, it's doable and will certainly push the truck's limits. Keep in mind, a 6,000# flat bed is a lot different than towing a 6,000# travel trailer.
    Just overall, that's a lot more trailer than I'd want behind a Tacoma.
  10. Dec 5, 2012 at 6:14 AM
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    I gotta agree. I have towed a similar sized unit with my previous taco but just short distances (less than 120 miles round trip or I needed extra gas cans) at less than highway speeds. I used a WDH and my truck was built up way beyond stock suspension so that wasn't an issue but "wear and tear" concerned me.
  11. Dec 5, 2012 at 6:32 AM
    Scorn
    Indiana
    TRS Sport Dbl Cab
    Thanks for everyone's input will scale it down to 23 or 25 ft and 3,500 lbs.:):)
  12. Dec 5, 2012 at 6:34 AM
    Scorn
    Indiana
    TRS Sport Dbl Cab
  13. Dec 5, 2012 at 6:45 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  14. Dec 5, 2012 at 7:12 AM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    I towed bigger once but I won't do that again. Emergency braking was scary as hell. Also highway speeds with big winds were scary - I had to keep the speed under 55.
  15. Dec 5, 2012 at 8:34 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i suspect you would get a more enthusiastic response if this was posted in the towing section. some of those guys push it a tad IMHO.
  16. Dec 5, 2012 at 8:45 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Not safely for you, your truck or anyone on the road around you.
    Yes, your truck will physically be able to move that trailer.
  17. Dec 5, 2012 at 9:00 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I agree with all the above. I have towed campers about half that size with various vehicles and had to be carefull with emergency stopping and also strong cross winds, so I would not recommend that. As others have said the truck can physically do it (A Tundra pulled the space shuttle the other day), but that's not the issue. Safety is way more important, and then also the wear and tear on your truck. You typically use the camper for vacation and to go relax, you don't want to be a nervous wreck after the trip.
  18. Dec 6, 2012 at 6:36 AM
    Scorn
    Indiana
    TRS Sport Dbl Cab
    25 ft long and here are the specs.
    Length25'10"Width8'0"Height8'9"Interior Height1'0"Hitch Weight481 lbsGross Weight7,481 lbsCargo Weight2,772 lbsDry Weight4,201 lbs
  19. Dec 6, 2012 at 6:36 AM
    Spruced UP
    Eric
    Jacksonville, FL
    No pics?
  20. Dec 6, 2012 at 10:05 AM
    Scorn
    Indiana
    TRS Sport Dbl Cab
