Can I Use A Air Pump In The Back Of The Truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, Aug 13, 2010.
  1. Aug 13, 2010 at 10:37 AM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
  2. Aug 13, 2010 at 10:40 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Why not get one that plugs into the cig outlet that's meant for it. I have one I got at walmart for $15 and it works like a charm and it's fast.
  3. Aug 13, 2010 at 11:02 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Aug 13, 2010 at 12:01 PM
    WATacoRider
    TRD Sport 4x4
    well it's a towable inner tube. So I need to fill it up really full and tight.
    Looks like I have to find one of those 12v versions instead. Maybe the kind that clamps onto the battery. I think they push more air than the ci outlet version. :confused:
  5. Aug 13, 2010 at 1:15 PM
    Jason'sLawnCare
    The wally world special one does 1 psi which doesn't sound like much but for a towable it's enough. That's what I use mine for. If you want more I believe westmarine has one that's good for 2 or 3 psi.
    If you get one for a cigarette ligher outlet you can use it on the boat and not fillup until you are ready to use the tube. My tube is huge and it's a pita to strap it down so I just stow it in the ski locker and fill it up when I'm ready. It takes like 5 minutes and I'm ready to play.
  6. Aug 13, 2010 at 1:22 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
  7. Aug 13, 2010 at 1:26 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I run this for filling tires off the back of my truck on the inverter...
  8. Aug 13, 2010 at 1:36 PM
    Jason'sLawnCare
    Not that that isn't a good suggestion it just with tubes you only fill them a couple psi and it's huge volumes. A tire pump would take forever to fill it up. I know because I made the mistake of bringing a bicycle pump and it took 4 people rotating about an hour to fill up. Even with my 12 gallon air compressor at home it takes about 10ish minutes.
  9. Aug 13, 2010 at 1:58 PM
    WATacoRider
    TRD Sport 4x4
    if you dont mind me asking, what tube do you have? I'm still searching for a tube that will work for us.
    Something easy to pull and ride on. Needs to be able to support a single adult weighing 160-220lbs.
    I was leaning towards this.
    http://www.amazon.com/dp/B000FE9CIM/ref=pe_86160_16559180_pe_epc_d1
    But it might be a little too big....
  10. Aug 13, 2010 at 2:20 PM
    JKD
    JKD Well-Known Member
    6.3 amps x 120v = 760 watts. Inverter is what, 500 watts max? No, wont' do it.
  11. Aug 13, 2010 at 2:23 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    I used a very small air pump this past weekend to fill about 10 rafts and tubes and ran it about 30 min without issue. Worked very well and impressed some people that didnt know jack about our beloved trucks
  12. Aug 13, 2010 at 3:29 PM
    Jason'sLawnCare
    Hahahaha. That's the exact one I have. It will hold 3 smaller people or 2 bigger ones easily. It has lots of handles but I would not reccomend it. Before it planes it has a tendancy to dig and go underwater:eek:. You have to lean back when going slow. I like to just go slow and relax sometimes and it can't be done easily on this tube. I would have to say it's really fun for the more aggresive stuff though and those headrests things help to push off of and lean into the turns.
    Oh and the tube is huge and that's why I have it deflated and stored in the ski locker until use.
    If I were to purchase another tube it would be like this
    http://www.overtons.com/modperl/pro...elly_Mega_Wing_Towable&aID=600G4&merchID=4006
    My friend has one and it's fun but can be relaxing at slower speeds and is easy to stay on.
  13. Aug 13, 2010 at 3:43 PM
    WATacoRider
    TRD Sport 4x4
    lol what a coincidence. Hmmm, looks like I need to find something smaller.
    That new one you're looking at is even bigger! 8 feet wide! :eek:
    Hmmm, I wonder how about this one.
    The O'Brien Screamer. I cant really decide if I like the 60" version or go for the bigger 70" version.....
    Can you lay down like in a cockpit position in this style of tube?
  14. Aug 13, 2010 at 5:02 PM
    Jason'sLawnCare
    With the flat style it's best to go belly down. You could get the one I posted in a 2 seater version which sould be smaller. I just like being able to sit down and it's a nice and easy going ride. The size doesn't matter to me as long as I can stuff it in the ski locker and not have to tie it to the back of the boat.
  15. Aug 13, 2010 at 5:57 PM
    WATacoRider
    TRD Sport 4x4
    bummer. Too bad they dont make an adult single seat version.
    Then again, I'm not too worried about speed. It's being pulled by a Merc 60 4-stroke motor in a 16.5' boat. :eek:
  16. Aug 13, 2010 at 6:16 PM
    Jason'sLawnCare
