Can I use Mobil 1 75W-90 LS in a non-limited slip differential?
Discussion in '1st Gen. Tacomas (1995-2004)' started by defleppardsg, Oct 8, 2012.
  1. Oct 8, 2012 at 6:59 AM
    defleppardsg
    defleppardsg [OP] Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    I searched... didn't find a direct answer... Bought a couple bottles of mobil1 75W-90 gear oil to change my rear dif, got home and realized I had grabbed 75W-90 LS gear oil. Will the LS oil be OK in my non-limited slip rear or should i just go and return em before i do it...?
  2. Oct 8, 2012 at 7:05 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    LS is compatible in non-LS rear ends but you can't put non-LS in an LS rear end.
  3. Oct 8, 2012 at 7:08 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    True, I guess I should have added that part.
  4. Oct 8, 2012 at 7:15 AM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    thanks for the quick response guys
  5. Oct 8, 2012 at 7:17 AM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    does anyone know how much oil the rear dif will take? also how much the transfer case will take?
  6. Oct 8, 2012 at 7:20 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Transfer case is a little over 1 qt I think.
