can i use same rim with bigger tire?
Discussion in 'Wheels & Tires' started by NRXTM, Mar 19, 2012.
  1. Mar 19, 2012 at 7:06 PM
    NRXTM
    NRXTM [OP] Well-Known Member
    Houston
    2011 toyota tacoma
    im about to buy a lift and i wanted to know if i could just use the same rims i have and bigger tires or would i have to buy rims with larger width?
    (probobly sound like a moron to you guys) btw pic is in sig
  2. Mar 19, 2012 at 7:15 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    How big of a tire were you thinking of going to? You should be fine with the ones you have unless you go ridiculously huge.
  3. Mar 19, 2012 at 7:18 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
  4. Mar 19, 2012 at 7:20 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Look on Tirerack.com
    Find the tires you are interested in.
    They will list the specifications including the recommended wheel width.
    Example: http://www.tirerack.com/tires/tires...ehicleSearch=false&fromCompare1=yes&tab=Specs
    Bridgestone Turanza 235/60-16 properly fits a rim anywhere from 6.5" to 8.5" wide.
    The specified diameter and section width are as measured on a 7" wide wheel. A more narrow wheel will pull the tire in a bit so it will not be quite as wide.
  5. Mar 19, 2012 at 7:21 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be able to stick with the same rim. Only issue you may come across is you may need wheel spacers to clear your UCA's.
  6. Mar 20, 2012 at 1:09 PM
    NRXTM
    Houston
    2011 toyota tacoma
    thank you
