Can I use the rearview mirror to power Radar Detector?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sg5845, Jun 2, 2010.
  1. Jun 2, 2010 at 11:55 AM
    Sg5845
    Sg5845 [OP] Well-Known Member
    Atlanta, GA
    2008 Tacoma TRD OffRoad Edition
    My 2008 Tacoma has the electrostatic rearview mirror (with the on/off switch). I just order the new Passport 9500IX detector and a rearview mirror mount and I want to run a dedicated power cable to it.
    Is there a 12V signal running to the rearview mirror that I could splice into to support the detector?
    As usual, thanks in advance for the help!
  2. Jun 2, 2010 at 1:53 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    green wire on the far left is 12v power
  3. Jun 2, 2010 at 1:56 PM
    Sg5845
    Atlanta, GA
    Cool, so that green wire plus a ground should do it. Correct?
  4. Jun 3, 2010 at 6:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Assuming that you don't pull more power then the wire, or the fuse it's on can handle.
  5. Jun 3, 2010 at 6:20 AM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    I am powering my GPS off the dome light circuit. Right up in that area is the mirror, compass and maplights. All these can give you a power and ground point to wire in the detector. Just grab a mulitmeter and make sure its switched with ignition or else it will always be on.
  6. Jun 3, 2010 at 7:23 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    When you get this all done please give the details. This is something that I want to do also.
  7. Jun 4, 2010 at 8:13 PM
    2K6 Taco
    2K6 Taco Well-Known Member
    Philly
    06 TRD Sport D-Cab LG Bed
    i have this done to my acura tl. i wired it to the rear view mirror.
  8. Jun 4, 2010 at 9:03 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    I would like to do the same thing...If you get it installed successfully, post up a DIY please:D
    Thanks in advance!
  9. Jun 4, 2010 at 9:04 PM
    747 function > form
    1st Gen.
    Might want to run an inline fuse...will the detector come with a hardwire install kit (like V1s do)?
  10. Jun 4, 2010 at 9:07 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i did a writeup how to install the rearview mirror and laid out what is switched power and what is ground. It would totally work no problem. It would even turn on and off with your key
    the link is in my sig if you need a guide.
  11. Jun 4, 2010 at 9:12 PM
    JTaco386
    JT
    San Antonio, TX
    I got an inline fuse system setup in my truck and plan on using it for this, I just wasnt sure if it would draw enough power for the radar detector.
  12. Jun 4, 2010 at 9:14 PM
    JTaco386
    JT
    San Antonio, TX
    Great write up! I'm looking at a few mirrors on ebay, one came from a highlander and the other came from a sienna. I'm just not sure if it's a trustworthy source to buy from...any opinions?
  13. Jun 4, 2010 at 9:20 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Thanks!
    both should be just fine. I think Toyota used the same one for most.
  14. Jul 6, 2010 at 3:23 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    i wanna do this too!!
