Can I use the stock rear shocks
Discussion in 'Suspension' started by bendbolden, Oct 25, 2011.
  1. Oct 25, 2011 at 6:07 PM
    bendbolden
    bendbolden [OP] Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    with a 1.5" or 2" AAL? I am putting 5100's on the front tomorrow and I am probably going to set them at 2.5". I will be getting an AAL next week but I am not sure if I want a 1.5" or 2". I am also unsure if the stock rear shocks will be okay for the AAL. I don't off-road much and am actually taking my first real trip in the truck this weekend. I know it will be better to get new shocks but can I run the stock ones with no problems as long as I don't go crazy wheeling?
  2. Oct 25, 2011 at 6:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Length-wise they will work although not idea. You have a regular cab so very light therefore I'd be careful with the AAL you choose. You could end up getting a little more than the advertised lift because of the lack of weight. The ride would most likely suffer since the stock shocks are soft and won't be able to dampen the stronger leaf pack. FWIW, I'm running stock height 5100's with 2" of lift in the rear. If I really flex out the rear, I know I run the risk of topping out the shock and blowing them out but if you take it easy you'll be fine for a while. Are you planning on swapping them out sometime in the near future?
    Also, the Icon or Wheelers 3 leaf AAL is an awesome product. It's a 1.5" AAL but if you leave the factory overload in place you can gain 2" of lift.
  3. Oct 25, 2011 at 6:25 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    IF tight on cash get the toytec shock extensions, cheap effective and will allow you to say up for the proper length shocks
  4. Oct 25, 2011 at 6:32 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I am pretty set on the 1.5" AAL with that being said. I will eventually swap out the rear shocks just doing it one step at a time. If I go with the toytec 1.5" AAL or Wheeler's 3 leaf do you think I should set the front 5100 at 1.75 or 2.5? I'm thinking 1.75. I would like it level but I don't mind a small rake. I think 2.5 would be nose high with a 1.5" AAL.
  5. Oct 25, 2011 at 6:38 PM
    08pretaco
    az
    wheelers 3 leaf, a lot softer. The toytec's i have are way to damn stiff. Get the progressive you will love it!
    If you dont like the bro then stick with 1.75. If you dont mind being a little back rake do the 2.5!
    Fish Taco 4x4 likes this.
  6. Oct 25, 2011 at 6:43 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I may just go with the 2" and a shock extender then. TOO MANY CHOICES!!! haha Let me sleep on it. Thanks
  7. Oct 26, 2011 at 5:57 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Ok guys last question before I finalize my order with Toytec. I am almost set on setting the front 5100's on 2.5 and getting a 1.5" AAL since many members said I wouldn't need new UCA's and that it would set pretty level like that. If anyone else can chime in to confirm this on a regular cab I would appreciate it. The only other option would be to set them at 1.75" and still get the 1.5" AAL but I believe that would cause a factory rake. I am also getting the shock extenders for the rear. Thanks
  8. Oct 26, 2011 at 6:40 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Looks good:D
  9. Oct 26, 2011 at 6:48 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Which would you recommend?
  10. Oct 26, 2011 at 7:08 AM
    Pugga
    Massachusetts
    Personally, I like a little rake but that's because I use my truck to tow and haul. Level looks nice but is not functional as far as I'm concerned.
  11. Oct 26, 2011 at 7:14 AM
    jimbo06
    jimbo06 Well-Known Member
    jim
    florida
    crewcab prerunner trd sport
    i have a double cab long bed with the billys set at 2.5 and i put helper springs on the rear, and its still nose high i like it but i fixing to get new rear leaf springs to pick it up but the truck rides great at 2.5 and i have stock uca
  12. Oct 26, 2011 at 7:37 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Yeah I def want it to keep some functionality/towing so I am gonna go with the 1.75 setting. Thanks for the help!
