Can it fit 2016 engine into a 2014 tacoma
Discussion in 'General Automotive' started by Jackolatern2, May 3, 2021.
  1. May 3, 2021 at 1:51 PM
    Jackolatern2
    Jackolatern2 [OP] New Member
    the trash state of the west coast
    2013 pyrite mica double cab long bed limited
    mbrp exhaust specter coldair intake
    Let's say hypothetically if an 4.0 v6 in the 2005 to 2015 engine were to get removed could a 3.5 v6 found in the new tacomas fit inside
  2. May 3, 2021 at 1:52 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Why in the actual hell would you want to do that?
    CJREX, Superdave1.0, Key-Rei and 4 others like this.
  3. May 4, 2021 at 4:10 PM
    Jackolatern2
    well lets not point fingers but lets say the engine were to go ca-put so to speak not saying it did but if it were to
    Wixo likes this.
  4. May 4, 2021 at 4:12 PM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    I think he's trying to say "why the hell would you want the 3.5 over the 4.0"
    whatstcp likes this.
  5. May 4, 2021 at 4:13 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    Sure but i wouldnt
  6. May 4, 2021 at 4:35 PM
    Jackolatern2
    why not?
  7. May 4, 2021 at 4:37 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Just get a rebuilt 4.0?
    Key-Rei likes this.
  8. May 4, 2021 at 5:42 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    Sport Crew represent
    Where would you get an ecm that would play nice with that setup?
    Key-Rei and shakerhood like this.
  9. May 4, 2021 at 10:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 3.5 is more complicated so it would not just be a bolt in, a replacement 4.0 would be a better and less expensive choice.
    tinker_troy and Key-Rei like this.
  10. May 4, 2021 at 10:54 PM
    whatstcp
    whatstcp currently drunk so don't listen to me
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    For that much work wiring and whatnot I rather just ls swap
    shakerhood, Rock Lobster and Key-Rei like this.
  11. May 4, 2021 at 10:59 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    There would be so much wiring upgrading to accommodate the new engine it would not even be close to worth it. New computers, new sensors, new wiring harness from donor truck.
  12. May 4, 2021 at 11:02 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Will it physically fit?
    Yeah, it is smaller after all and that said the 2JZ, 2UZ, 3UR, and even the LS family can all fit comfortably in the Tacoma's massive engine bay.
    If you have a manual transmission it will even bolt up and the clutch will still work.
    But you would need all the ECU stuff and the emissions stuff and probably new fuel stuffs and basically anything electrical not handled by the old trucks BCM, and even still you'ed probably never get the gauges working and would have en eternal CEL.
    So as other have said why in the cinnamon toast fuck would you want to put a higher reving lower torque and more complicated motor in your truck?
    Just get a used 4.0
    You could probably get one from an early FJ or 4Runner or even Tundra so long as it's single VVT-i and not Dual VVT-i (different heads and extra sensors) it would be plug and play.
    What are you hoping to gain through the 3.5 engine?
    If you're looking for better fuel economy you will actually get worse as the fuel economy the 3.5 gets over the 4.0 is thanks to the transmission more than anything and even still reall world numbers are typically lower than the 4.0 especially when your truck is modified.
  13. May 4, 2021 at 11:16 PM
    Gearheadesw
    Davenport Fl
    Cinnamon toast, yum.
  14. May 21, 2021 at 6:14 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I put an 08 FJ engine 4.0 into my 05 Tundra 4.0. The FJ has a larger 6 qt oil pan and the Tundra only fits with a 5qt Xrunner pan.
  15. May 21, 2021 at 6:25 PM
    Key-Rei
    Key
    Florida
    Be careful with that. At some point the FJ got the dual VVT-i motor like the 5th gen 4Runners over the single VVT-i motor that the Tacoma only had ever.
    A dual VVT-i does make a little more power but due to the head differences and additional sensors etc. It will not work in the Tacoma without an full main harness and computer change.
  16. May 21, 2021 at 6:37 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    What people are saying is that the 4.0 is a better engine then the 3.5
    CJREX and Key-Rei like this.
  17. May 21, 2021 at 7:23 PM
    specter208
    California
    The engine I got is completely compatible.It is an single VVT-I 08 4.0 same as in 05-10 4Runner, 05-11 Taco and 05-09 Tundra. The install was successful, I only had to swap the oil pans because 1st gen Tundra chassis only fits the shallow oil pan from the Xrunner.
