can only pick one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arktacoma, Mar 9, 2011.
  1. Mar 9, 2011 at 7:22 AM
    arktacoma
    arktacoma [OP] Well-Known Member
    arkansas
    11 sport double cab
    hey guys here the thing .. would you wait a month and get 3in lift but i would have to run stock rims and tires for a while . OR do you just not lift it and get tires and rims on stock ht. 2011 trd sport dbl cab. thanks for the help . the boss said i can only do one. gaaaaa
  2. Mar 9, 2011 at 7:32 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    If you want a 3" lift do it first and get new wheels and tires later. If you do the wheels and tires first you'll be limited by your stock susp.
  3. Mar 9, 2011 at 7:38 AM
    arktacoma
    arkansas
    11 sport double cab
    will it look alright with 3in lift and stocks? thanks
  4. Mar 9, 2011 at 7:38 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    ^^ this, lift first if u want a 33 in tire
  5. Mar 9, 2011 at 7:40 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    Get the lift first, then your wheels and tires.:D
  6. Mar 9, 2011 at 7:44 AM
    TexAggie
    Eric
    Amarillo, TX
    OME Lift
    Maybe a little, but in the long run you'll be happier. If you do wheels and tires first then a lift it will look that way always. You can also look at smaller lifts for cheaper, like the 5100's for about a 2" lift. Then you could get wheels and tires sooner since you saved money on the lift.
  7. Mar 9, 2011 at 8:09 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    why not wait, save up and do both at once since you eventually will do both anyways. Doesn't make sense to get different wheels/tires without a lift if you will go bigger tires later after lift. Getting lift first with stock tires will not look right. Do it all at once, get one alignment, and fix any issues that you may have then. (ex: needing UCA's). Do it once and do it right.
  8. Mar 9, 2011 at 8:11 AM
    TacomaNC
    TacomaNC Active Member
    NC
    borla exhaust tintind windows
  9. Mar 9, 2011 at 8:12 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Do the lift now, then wheels and tires later. Look on the for sale section here and on craigslist for a good set of used wheels and tires. After I installed my lift, I found my wheels and tires used in the for sale section for a good deal. Saved about $800 over the price of a new set of wheels and tires.
  10. Mar 9, 2011 at 8:16 AM
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    When I lifted my truck I had to wait a couple weeks for my rims to come in. It looks a little funny with the 265's but who cares. In the end wit doesn't what other people think, do what makes you happy.
    The question you really need to answer is are you going to lift it down the road if you get the rims and tires first. If the answer is yes then I would go with the lift first so that you can get tires that will complement the lift.
    Good luck with your decision.
  11. Mar 9, 2011 at 8:28 AM
    arktacoma
    arkansas
    11 sport double cab
    alright thanks for reponses and i believe i will do the lift first and then either find used tires and rims or buy new thanks
  12. Mar 9, 2011 at 8:30 AM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    3" lift & stocks will be fine. I did it for 2 weeks. check my pics
  13. Mar 9, 2011 at 8:36 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    I would say to buy rims and the tires you want to put on when you lift it. You could always install the rims on your stock tires and save the 33's for when you buy the lift. You have a 2011, so you couldn't possibly need new tires RIGHT NOW. It should only take a couple of months to save up enough for some Billies and Eibach's.
  14. Mar 9, 2011 at 12:24 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
  15. Mar 9, 2011 at 12:37 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    lift first then wheels and tires +14
  16. Mar 9, 2011 at 12:38 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    x2
