Can someone verify Bilstein 5100 part #'s for me please? Also a lift question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ian02, Apr 9, 2015.
  1. Apr 9, 2015 at 7:01 AM
    Ian02
    Ian02 [OP] Active Member
    Ian
    Raymond, NH
    '15 Tacoma AC 4x4 4 cyl MT
    Bone Stock
    New guy here, sorry for the stupid question but I want to get it right the first time.
    I've seen 2 different types of part #'s for 5100 shocks for my truck.
    Fronts I've seen are 24-239370 or BE5-C477
    Rears I've seen are 24-186728 or BE5-C478
    Do these #'s look accurate?
    2015 Access Cab 4cyl 4x4 MT
    Now onto the lift question. I want to run a 285/75-16 or 285/70-17. It's never going to go off road, I'll be honest. As far as towing, the only thing it may tow is going to be a tiny boat or small utility trailer, so nothing heavy.
    I want to do the 5100s with the fronts on the lowest setting.
    These springs without the upper spacers: http://toyteclifts.3dcartstores.com/Toytec-3-lift-front-coil-springs_p_1205.html
    This rear AAL: http://toyteclifts.3dcartstores.com/Toytec-Progressive-3-Leaf-Add-A-Leaf-Pack_p_976.html
    Knowing what I have for a truck and it's intended usage, is this a decent selection of parts? I want to run the 285s (33") and not have any clearance issues. If I run a wheel with -12 offset I should clear the UCA right?
  2. Apr 9, 2015 at 8:05 AM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
  3. Apr 9, 2015 at 10:52 AM
    Ian02
    Ian
    Raymond, NH
    Bone Stock
    Thank you sir
  4. Apr 9, 2015 at 11:41 AM
    str808taco
    str808taco Active Member
    Sheldon
    Hilo,Big Island
    2014 Tacoma TRD offroad
    3" OME w/5100's upfront & 2.5" blocks in the back with bilstein 5100's. 17x9 Fuel's on 265 70 17 cooper stt maxx . 48 led dome light , led corners , led 5 cree headlights & HID 8k fogs. Switchback & fog light mods done .
    are theses the same part numbers for 2014 DC 4x4 V6 ?
  5. Apr 9, 2015 at 12:08 PM
    mAtTyG04
    Edmonton
    2019 Quick Sand OR
    yes
  6. Apr 9, 2015 at 1:02 PM
    Ian02
    Ian
    Raymond, NH
    Bone Stock
    So this # is valid for all 2nd Gen trucks then?
  7. Apr 9, 2015 at 1:05 PM
    mAtTyG04
    Edmonton
    2019 Quick Sand OR
    Yes
    MODELYEARFRONT LIFTFRONT PART #SHOCK SERIESNOTES 4wd/2wd Tacoma 6 Lug (Prerunner)05-14 0-2.5" 24-239370 5100 Adjustable
    Rear Shocks Application Table-
    MODELYEARREAR LIFTREAR PART #SHOCK SERIESNOTES 4wd/2wd Tacoma 6 Lug (Prerunner)05-140-1.5" 24-186728 5100 Series 4wd/2wd Tacoma 6 Lug (Prerunner)05-143"-4" BE5-B110-T5 5100 Series 4wd/2wd Tacoma 6 Lug (Prerunner)05-140-1" 25-177343 5160 Series
  8. Apr 9, 2015 at 1:10 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    ‘13 Taco, ‘14 T4R, SC430
    If your lifting that much don't forget to add UCA's to the list, you'll never get the alignment correct without them. Mine is barely @spec with 5100's @1.75 on stock springs.
  9. Apr 9, 2015 at 1:26 PM
    mAtTyG04
    Edmonton
    2019 Quick Sand OR
    Ya typically under 2.5" you can get good alignment without aftermarket UCA's. Save your $$$.
  10. Apr 10, 2015 at 11:19 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
  11. Apr 10, 2015 at 12:49 PM
    Bjwilms7
    Bjwilms7 Well-Known Member
    Brandon
    Fairfax, VA
    09 Tacoma TRD Sport DCSB 4X4
    Billet grill, 20% tint, 265/70/17 BF Goodrich tires, 3" smittybilt nerfs, weathertech guards, Toytec 3" lift (Bilstein 5100s front/rear, Eibach, AAL), LR UCA's
    Yep, have 5100s and the eibach coil and couldn't get it in specs....just purchased LR UCA's.
