Can TPMS be bypassed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spruce Juice, May 26, 2012.
  1. May 26, 2012 at 8:47 PM
    Spruce Juice
    Spruce Juice [OP] Well-Known Member
    Sam
    Vancouver, BC
    2012 4 x 4
    Fold A Cover, Factory Class 4 Hitch with Factory Harness, Cruise, Int Wipers, TRD Alloys, Fogs, K&N Air Filter
    I am looking to switch my 16" steelie rims to alloys. With some alloys I have to buy new tire pressure monitor sensors because while my wheels come with 20 degree sensors some alloys take 40 degree sensors. Rather than spend $80/sensor x 4, I would rather not have sensors. I can maintain my own pressures. Always have. Can the system be turned off or by passed? I would hate to have a lamp lit up in the dash while I'm driving so if nothing can be done I would take out that bulb.
  2. May 26, 2012 at 8:57 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    No bypass, the light will remain on indefinitely. Sorry
  3. May 26, 2012 at 8:58 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Keep the TPMS sensors in a pressurized vessel in the truck
  4. May 26, 2012 at 9:02 PM
    Johns Taco
    Albuquerque, NM
    :laugh:
  5. May 26, 2012 at 9:08 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    People do it all the time.
    Here's one that someone here posted.
  6. May 26, 2012 at 9:11 PM
    Johns Taco
    Albuquerque, NM
    Interesting pvc deal.
  7. May 26, 2012 at 10:58 PM
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    Seeems like a pain in the ass...i say put up with the light !
  8. May 26, 2012 at 11:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There is a way to "silence" the light.
    It involved cutting a wire and, depending on the year, either grounding it, or routing power to it.
    Most are using 12v, it really wants to see +5, but personally when I do the mod I'll use 12v with a 5k pullup resistor.
  9. May 27, 2012 at 2:29 AM
    babytruck
    NorCal
    A lot of the people in my car club do that because the TPMS won't fit on the custom wheels that they often have. So something like this is quite common. Some even paint to match the car since it's often stored in the trunk and the cars are brought to many car shows.
  10. May 27, 2012 at 5:00 AM
    tim allan
    tim allan Well-Known Member
    apex, nc
    2017 double cab trd offroad
    when I go to work on monday I will see if our tech information system has a option to turn it off,
  11. May 27, 2012 at 5:07 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I have yet another way :D
    take small piece of 1/2" long electric tape
    place over light on dash
    in all seriousness though I don't even notice mine on any longer. You get used to it after a while.
  12. May 27, 2012 at 9:19 AM
    OZ-T
    Peter North
    British Columbia
    How hard is it to glue 3 pieces of pipe together ?
  13. May 27, 2012 at 11:15 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    That's what I did when my spare tire sensor rotted off....I ain't paying $50.00 for a new one... I don't see the light anymore....
    Don't make your tape any bigger than 5/8" x 5/8" square or you might block the other lights....
    Works for me...
  14. May 27, 2012 at 11:47 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nope.
    Federal law all vehicles manufactured after 2008 have to have it.
    Toyota started out with an indirect system (read based on ABS sensor readings for wheel speed) as early as 2004 on some models.
    There is no software way to disable it, and you will not be able to get a shop to do it through hardware "above board" since it would be a violation of Federal law for them to do so.
    Either DIY, or if you have a good relationship with a tech that will do it "under the table" while you have it in for an oil change or something.
  15. May 27, 2012 at 11:49 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That assumes you have a working system.
    Mine isn't. The light flashes for a minute or so on startup and stays on.
    I have 5 sensors in my 5 wheels. They're all at 35psi.
    I'm not going to go buy 5 more sensors just to stick them in a tube. If I'm going to buy 5 new sensors, they're going in the wheels where they will work.
    But I'd rather just not have the system at all.
  16. May 27, 2012 at 12:01 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Or you can try a strap kit. Dunno how well they work, but maybe worth a shot OP. The link is just from a random Bing search so DYODD as to whether or not this works on your particular setup.
  17. May 27, 2012 at 1:15 PM
    OZ-T
    Peter North
    British Columbia
    I assumed the OP has a working system by his question
  18. May 27, 2012 at 1:26 PM
    Johns Taco
    Albuquerque, NM
    This strap system works on Fords that have TPMS sensors that conform to the inner rim and have slots for the strap to fit through them (strap is more like a giant hose clamp that goes all the way around the rim). The Toyota ones are not meant to that at all.
    Ford tpms
  19. May 27, 2012 at 1:30 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    I did the disable mod that works on 05-06. Unplug the module and ground the blue wire that goes from the module to the cluster light. Screw tpms.
    Theres always a way to disable but you need the wiring schematics.
  20. May 28, 2012 at 3:35 AM
    Hot2na
    Hot2na Well-Known Member
    Where on the vehicle would you store the PVC pipe setup?
    center console ? glove compartment?
    any more people use this PVC pipe mod ??
