Can you combine a 3" lift kit with a 6" to get 9" total?
Discussion in 'Suspension' started by XBobbyX, Nov 12, 2008.
  1. Dec 16, 2010 at 5:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What's unpractical about a solid front axle? Trucks had solid front axles for years before IFS became popular. The solid axles are extremely tough and much lower maintenance than the IFS with multiple joints. Solid axles tend to ride rougher which is most likely why most manufacturers switched. Besides the high initial cost of doing the swap, there's nothing wrong with a solid front axle.
  2. Dec 16, 2010 at 8:46 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i know someone who ran coilovers with that lift... it's doable... just ends up looking goofy in a Tonka toy kinda way....
  3. Dec 16, 2010 at 8:57 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 I would rather have Solid axle less things to break. Jeeps still have them and the ride is not that bad. If i could afford it I would be doing a SAS right now but it will have to wait until the truck is a little older.
  4. Feb 4, 2012 at 12:30 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    I think it would be a great mod to do a solid axle swap even if you dont wheel it really hard. it would wheel great when needed and strong as a tank and you wouldnt have to worry about things breaking or dealing with clearance issues or travel issues. i o wish i had the solid axle so i wouldnt have to worry about shock travel you could put an extra leak in for extra height or leave it stock height and still have the stretch you need. they put coils on rockcrawlers you could do that for you r street ride its alot easier to lift a solid axle.
  5. Feb 5, 2012 at 11:57 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    umm stacking lifts rofl why and how? No way you can stack a lift and it be functional... driveline issues rear springs to match.. coils? would have to be aftermarket like race runners or king or fox or airshocks..... BIG money$$$$$ plus all the weak links that would be used to bolt or weld the two kits together... and steering and brake line's power steering hoses lol by the time you spend all the money to make it work you could have bought a long travel kit and fiberglass fenders or a solid axle kit and some crawler box's and a supercharger lol not worth the risk nor worth the time money and it will look dumb as hell lol
  6. Feb 6, 2012 at 12:01 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    this thread is 4 years old. :anonymous:
  7. Feb 6, 2012 at 12:06 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    lol. last post was in 2010.
  8. Feb 6, 2012 at 12:06 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    wonder if it was ever done lol
  9. Feb 6, 2012 at 12:06 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    :cookiemonster:
    you posted in it last year too
  10. Feb 6, 2012 at 12:07 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I hope not...
  11. Feb 6, 2012 at 12:08 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    hahahahaha yeah someone commented on it and so it popped up lol i never look at date lol... and i never got an answer to my ? from that guy
