Can you guys help me figure out this noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrandonM3, Feb 24, 2019.
  1. Feb 24, 2019 at 3:13 PM
    BrandonM3
    BrandonM3 [OP] Member
    I've been googling like a madman the last couple days and finally found an obscure video that captures the noise exactly. It happens on my truck with the same intermittent timing and while the car is simply idle and stationary.
    https://www.youtube.com/watch?v=ez4-hwlNMCc
  2. Feb 24, 2019 at 4:22 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I had the same noise, thought it was center carrier but turned out to be universal joint at rear end.
  3. Feb 24, 2019 at 4:45 PM
    BrandonM3
    A lot of research has pointed to that, but the noise happens whether the drive shaft is spinning or stationary. Wouldn't that rule out the u-joint?
  4. Feb 24, 2019 at 4:51 PM
    Rachelsdaddy
    Southern NH
    I was unaware of that... my bad
  5. Feb 24, 2019 at 4:57 PM
    Rachelsdaddy
    Southern NH
    Have you considered removing the belts just for giggles? It could be a water pump failing or another belt driven accessory. If not I imagine its time to look at tranny.
    toyodajeff and mtip like this.
  6. Feb 24, 2019 at 4:58 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Manual trans?
  7. Feb 24, 2019 at 4:59 PM
    BrandonM3
    I think I might try that. I haven't so far because I'm certain it's coming from the transmission area, but who knows. Simple enough to give the belts a shot.
  8. Feb 24, 2019 at 4:59 PM
    BrandonM3
    I wish. Auto :/
  9. Feb 24, 2019 at 5:01 PM
    1st4x4
    sam
    Torrance
    I was going to say throw out bearing but never mind
  10. Feb 24, 2019 at 5:13 PM
    Rachelsdaddy
    Southern NH
    If it ain’t a belt, or some dumb exhaust squeek it may be a cracked starter flexplate, let’s pray for dumb stuff. Good luck
  11. Feb 24, 2019 at 5:54 PM
    BrandonM3
    Hmm, didn't consider an exhaust squeak...
  12. Feb 24, 2019 at 6:12 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    When the Ujoint went bad on my '86 Jimmy years ago it made that exact sound but it was a "chirp" that increased with shaft revolutions.
  13. Feb 24, 2019 at 7:27 PM
    Indy
    Indy Master of all I survey.
    If it happens when stationary, its not transmission related. Flex/pressure plate.
  14. Feb 24, 2019 at 7:29 PM
    BrandonM3
    It's an auto :/
  15. Feb 24, 2019 at 7:31 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Yea sounds like it could be the belts but not sure about a noise like that from the transmission area. Does it happen when the engine is hot or cold?
  16. Feb 24, 2019 at 7:31 PM
    Indy
    Then torque converter. Regardless of tranny type, if the noise is coming from the bellhousing and the truck isn't moving, the issue is the parts joining the tranny and the engine together.
  17. Feb 24, 2019 at 7:34 PM
    BrandonM3
    Mmmm, both. And just like the video, it's super random in its appearance. Sometimes it chips, a few seconds of no chirp, starts chirping again, another gap of nothing for 45 seconds, then another, on and on. Super random, no regular interval. When driving, it sounds like the sound a bad throwout bearing makes. But of course, it's not that since it's an auto.
  18. Feb 24, 2019 at 7:36 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Get a peice of maybe garden hose that's a a foot or 2 long. Or 1/2 heater hose. And stick it to your ear then kinda wave it around under there where you think the noise is. Itll be easier to pinpoint like that.
