Can you guys tell me a bit about 2 strokes?
Discussion in 'All Terrain Vehicles' started by Unknown, Sep 21, 2010.
  1. Sep 21, 2010 at 3:54 PM
    Unknown
    Unknown [OP] He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    I heard about "fouling plugs" but whats that?
    Do i got to keep it in high RPMs?
    I check "thumpertalk" but no luck
  2. Sep 21, 2010 at 4:04 PM
    trailmaker
    trailmaker Well-Known Member
    northern ca
    4wd reg cab
    I think older two strokes could foul plugs if run at low rpms.
    A modern two stroke should not foul plugs regularly. If it does you may need to adjust jetting in the carburetor. Running the wrong oil ratio might also be a problem.
  3. Sep 21, 2010 at 4:09 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Often plugs are fouled from incorrect oil fuel ratio.
    More often from setting the carb too rich.
    Some old bikes had oil injection so you did not mix it with the gas.
    Emmission controls pretty much killed the 2 stroke.
  4. Sep 21, 2010 at 4:11 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Plenty of torque but not worth my time for maintenance issues.
    Not necessarily high rpm's, but keep it in the "power band."
  5. Sep 21, 2010 at 4:17 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Four stroke... FTW
  6. Sep 21, 2010 at 4:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Well a properly set up 2 stroke should idle all day without fouling. You just need to have the jetting right.
    I lug my bike all the time in the mountains and scream it in the desert and it doesn't miss a beat. I can also always get the hole shot against the 4 strokes in the harescrambles because my bike starts in gear first kick every time (dead engine starts).
    Oh and 2 stoke FTW!:p
  7. Sep 21, 2010 at 5:17 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You're not going to get any info from Thumpertalk, Thumpers are 4 strokes.
    2 strokes don't have the low end power of a four stroke so you're better off keeping RPMs up. A 4 stroke will lug way down and has the torque to just roll on the throttle and rev back up. A 2 stroke has a more narrow power band and is more towards the top of the rev range so you end up downshifting rather than lugging the engine. Newer 2 strokes are certainly much better than the old ones and should idle fine and are built with better low end power than the old ones. It also depends on what the bike was built for and any aftermarket parts. A motocross bike will not have much for low end power and will run much better when wound out and should have a pretty knarly power band. A trail bike will have more even power delivery through the rev range and a fairly even tempered power band. Aftermarket pipes, carbs and jet kits can dramatically change the characteristics of the 2 strokes.
  8. Sep 21, 2010 at 5:19 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeah, stay in the powerband with 2 strokes, I have personally blown up 1, and it was my goped :D.
    Your in cali so if you do get a dirtbike the magic year is 2003 and older to keep a green sticker.
  9. Sep 21, 2010 at 5:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Actually Thumpertalk is awesome, even for 2 strokes.
    I believe the OP is looking at getting a KTM 250 though so KTMtalk is also really good.
    Also most of this info is true for 125's, but not the newer 250's. No need to keep a 250 wound out unless your in a sandwash.
  10. Sep 21, 2010 at 5:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Oh, forgot about that.
    In that case, I would look for a nice yz125 or 250 older than '03.
  11. Sep 21, 2010 at 5:27 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    As it's been mentioned already, you shouldn't be fouling plugs unless it jetted wrong/carb is not adjusted right or the fuel mixture is off.
    If you've never ridden a two stroke before, ride some and you'll get the notion pretty quick on whether or not you like how they ride and feel compared to a four stroke.:)
  12. Sep 21, 2010 at 5:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    LOL, going to "thumper talk" for info on a 2 stroke ??:D:D
    Oh yeah one bit of info , 2 stroke will run backwards
  13. Sep 21, 2010 at 5:32 PM
    Pugga
    Massachusetts
    Agreed, I had no idea what kind/size of bike the OP was referring to. I had an old '73 2 stroke that was extremely tempermental and much different than my 80's 2 strokes which were different still from those made in the 90's and later. I tried to give him the general overview not really knowing what he was looking for. Good luck OP!
  14. Sep 21, 2010 at 5:34 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :thumbsup:
    Yeah, bikes have changed a little bit since the '80's :D
  15. Sep 21, 2010 at 5:37 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    x2. Plenty of 2stroke info on Thumpertalk. You might have to work at it a little: you can find good general 2 stroke info in the YZ250 section if you don't find it in the KTM section.
    Fouling plugs isn't a big concern for me. The only time I have issues with plugs is when I'm rejetting after new a new pipe or top end.
    2strokes are happier when you're in the power: Chainsaws, for example, are just little 2 strokes, they work well at idle and full throttle; running them inbetween just mucks things up.
    For you haters: Someone is working on a direct injection 2 stroke engine= goodbye 4strokes. The popularity of 4stroke dirtbikes is all a big conspiracy from Honda anyway. But I do love my 4stroke too.....
  16. Sep 21, 2010 at 5:38 PM
    ktmrider
    Junk
    Yup cali sucks. The yamaha would be my choice as well
  17. Sep 21, 2010 at 5:39 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    X10. Oh how I love them 2 strokes. I'll add an TZ, YZ or RZ/RD to my collection, any day.
    Watch this vid where a TZ250 is giving a R1 a run for the money. Those TZ's are badass :drool:
    http://www.youtube.com/watch?v=OL7ZbomydgI
  18. Sep 21, 2010 at 5:42 PM
    nvdeserted
    Reno, NV
    Oh yeah, original question. You need to mix oil/gas for 2 strokes so buy a measuring cup. You'll need to learn how to use the clutch. And there isn't any engine braking, that's what the brakes are for.
    After that it's all fun and you'll be happy when you save $$$ by doing your own work on them, very basic motor.
  19. Sep 21, 2010 at 5:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Also don't use castor based 2 stroke oil if your not going to be screaming it all the time because it tends to clog things up (even though its smells really really good).
    I use belray MC1 and have been using the same spark plug for at least 25 hours.
  20. Sep 21, 2010 at 6:01 PM
    Tacomadude89
    Austen
    Ya, I was going to say there are sections for 2 strokes on TT.
