Can you help me identify a squeaky wheel sound?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razro95, May 17, 2019.
  1. May 17, 2019 at 9:09 PM
    Razro95
    Razro95 [OP] New Member
    2010 Magnetic Grey Double Cab Long Box
  2. May 17, 2019 at 9:13 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    A squeaky u joint doesn’t require emergency help...
    pinktaco808, b_r_o and tcjacado like this.
  3. May 17, 2019 at 9:15 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Help is reserved for being stuck somewhere.
    tcjacado, Crodell6 and Bebop like this.
  4. May 17, 2019 at 9:17 PM
    tcjacado
    tcjacado Well-Known Member
    Please change the title of the thread at the top using thread tools
  5. May 17, 2019 at 9:17 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I agree
  6. May 17, 2019 at 9:17 PM
    theredofshaw
    Mods were quick on that one.
    tcjacado likes this.
  7. May 17, 2019 at 9:18 PM
    tcjacado
    Oh.... and welcome to TW
    b_r_o and Crodell6 like this.
  8. May 17, 2019 at 9:25 PM
    Razro95
    They checked the U Joint and it's not that
    b_r_o likes this.
  9. May 17, 2019 at 9:29 PM
    Bebop
    Nick
    How did you check it? You physically pull it apart and inspect the needles inside the caps?
  10. May 17, 2019 at 10:30 PM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    The proper way to check a u-joint is to drop the driveshaft down and wiggle them around. If the shop didnt ask for any labor/inspection time then its likely they did not check them properly
  11. May 17, 2019 at 11:18 PM
    Bebop
    Nick
    When I got one of those free checks with no labor I had fun with them. Get a ticket that says check u joints. I would just write, “yup, it’s there”
    b_r_o[QUOTED] likes this.
  12. May 17, 2019 at 11:20 PM
    Razro95
    They already said that there is no play in the U joint. They don't have to charge me the Labor to inspect it.
  13. May 17, 2019 at 11:20 PM
    Bebop
    Nick
    Just because there is no play doesn’t mean it can’t squeak.
    No labor means the tech doesn’t give a fuck. He’s getting exactly 0 dollars to waste his time to check it.
    b_r_o likes this.
  14. May 18, 2019 at 2:17 AM
    b_r_o
    Alex
    WA
    2015 DCLB
    You're not just looking for play, you're looking for a "tight spot" in the needle bearing cups as you articulate the joint back/forth, up/down. You can't do that unless you remove one end of the driveshaft and let it hang down.
    What Nick is saying is that if they arent getting paid (the necessary time) to properly check it out then they probably just hurried through it and missed a bad u-joint... thats what it sounds like to me just listening to the video
    Bebop likes this.
  15. May 18, 2019 at 3:33 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    While that might be a carrier bearing it sounds like a classic failing U-joint. The next step will be worsening vibration and then bang, it will break and the drive shaft end will drop to the ground and/or flail around under the truck. Is there rusty dust around either or both joints and did they grease them?
  16. May 20, 2019 at 7:26 PM
    Razro95
    Update: It no longer makes this noise.
