Can you mix All terrain tires and all seasons
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bsponge, Dec 2, 2011.
  1. Dec 2, 2011 at 9:38 AM
    bsponge
    bsponge [OP] Member
    Edmonton, Alberta
    2007 Tacoma TRD Sport
    I earlier posted my dilemma about winter coming and having 6/32 tread on front tires and 4/32 tires on the back set. Currently running Bridgestone Dueler H/T 684 II's OEM's. I was able to find a supposedly 1 year old pair of used Bridgestone Dueler A/T Revo's with 9/32 tread remaining for $140 installed and balanced.
    I was thinking of putting the Revo's on the back as replacement for the 4/32 H/T 684's and leaving the front 6/32 pair on for the winter.
    Does the forum think this combo will work fine or is there a safety hazard mixing the 684 II's highway all seasons on the front and all terrain Revo's on the back?
  2. Dec 2, 2011 at 9:41 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As long as they're the same wear status left-to-right it otter be OK. However if the diameter of the tires front-to-back is sufficiently different, it'll confuse the ABS system and throw a code, and disable ABS.
  3. Dec 2, 2011 at 9:42 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    2010 double cab tacoma TRDoffroad SR5 V6 4x4
    I wouldn't think it would be a safety hazard but alot of car poeple run mix matched tires.
  4. Dec 2, 2011 at 11:06 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I ran mixed tires on my 94 toy pickup for 200k miles without an issue...I ran Michelin X-One tires on the front year round and putting a set of six ply traction tires on for the winter, in the P205/70R14 size:)
  5. Dec 2, 2011 at 11:11 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    You should be fine, just don't don't rotate them.... :eek:
