Can you put 17's on a stock regular cab 4X4
Discussion in 'Wheels & Tires' started by Drogers, May 16, 2010.
  1. May 16, 2010 at 3:15 PM
    Drogers
    Drogers [OP] Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    Can you put 17's on a stock regular cab 4X4?
  2. May 16, 2010 at 3:17 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
  3. May 16, 2010 at 3:47 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ^^ yup, it's the tire size u'll need to worry about
  4. May 16, 2010 at 3:50 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    and as far as that goes, you can go up to 265/70/17 on stock suspension without rubbing.
  5. May 17, 2010 at 6:13 AM
    Drogers
    Derek
    Sayville, NY
    Thanks, this is helpful. Do you see any benefit in doing this as far as off roading goes? It certainly will look better.
    Also, will this decrease my gas mileage considerably?
    Thanks, a lot!
  6. May 17, 2010 at 6:15 AM
    TexasTacoma37
    For offroading, the 17's would be slightly less desirable than 16's, because there would be more rim and less sidewall.
    If you are staying with he same tire diameter, the new wheels will have very little effect on gas mileage, unless they are considerably heavier than stock.
  7. May 18, 2010 at 2:02 PM
    Drogers
    Derek
    Sayville, NY
    Thanks a lot man. Would you just stick with 16's if you were in my shoes?
    Can you recommend a good tire to use? I do some beach and trail off roading. Maybe once or twice/week.
  8. May 18, 2010 at 2:15 PM
    Drogers
    Derek
    Sayville, NY
    I was looking at these ATX Chamber wheels. I think they would look sweet on my magnetic grey reg cab. They seem like a good quality wheel too. They are 16X9's.
    The recommended tire size for that wheel is 265/70 R16. Do you think I'll have any rub problems with this set up? Do you know anything about ATX?
    I appreciate your insight and helping me out.
  9. May 18, 2010 at 2:21 PM
    TexasTacoma37
    265/70/16 is the same size as stock. you can get away with up to 265/75/16 without any issues.
    I am happy with the tires I have, Hankook Dynapro ATMs, but there are other good tires out there.
  10. May 19, 2010 at 4:51 AM
    Drogers
    Derek
    Sayville, NY
    Ok, I thought stock was 245/75-16?
  11. May 19, 2010 at 5:38 PM
    The_Hodge
    SC
    the stock TRD OR stock is 265/70/16 and Sport is 265/65/17. some of the regular SR5s are 245/75/16.
  12. May 20, 2010 at 8:08 AM
    Drogers
    Derek
    Sayville, NY
    Oh I see. I have Sr5. Looks like it has good clearance and space to house 265/70 R16. What do you think?
  13. May 20, 2010 at 8:20 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    They will fit fine, what the other guy was saying was you can fit 265/75/16 with out rubbing issues, that's what I would go with if I was in your shoes.
