can you splice in a second horn? + i need a wiring schematic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by packfan88, Sep 18, 2011.
  1. Sep 18, 2011 at 1:42 PM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    I was at harbor freight and picked up a dual tone (high and low) set or regular ole horns for $10. I was wondering if you can connect them in series to the existing horns for a "double the loudness" horn sound.
    I wouldnt want to wire them up seperatly cause it would require hittign two buttons for the horn. Either that or I would have to do some in cab rewiring to get them both to function off the stering wheel. I would prefer to do the wiring thats needed ath the location of the horns if possible.
    Any info?
    On a side note, where can i get a schematic of the fuse box to find an available power wire for another device I am hooking up. I need to find a wire that will power a device that only works when the vehicle is on, but I will have a toggle switch to it so it only comes on whe nthe car is on AND when i flip the toggle switch. Anyone have the location for that wire?
  2. Sep 18, 2011 at 1:45 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    My guess is that you could splice into the existing horn wire and be fine. But the best way to do it would be to add a relay that is activated by the existing horns. Shouldn't be that hard. Sorry I don't have any wiring diagrams for ya.
  3. Sep 18, 2011 at 1:47 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm not sure how much louder it's going to make it....just thinking through this in my head, if you have one speaker playing at a certain volume and you put another one next to it at the exact same volume, is it really "louder"?
  4. Sep 18, 2011 at 2:09 PM
    TexasTacoma37
    Hmm I would think that's only because each snap is going to have a different, unique sound to it, therefore a different wavelength and frequency, leading to positive interference of the sounds waves. I'm not sure the same could be said for two identical tones.
    Example, a speaker makes a certain sound decibel level if you set the radio to, say, a volume of 5.
    So all the speakers are playing at a volume of 5. If one of your 4 speakers dies, are the others still not playing at a volume of 5 producing the same deicbel level?
  5. Sep 18, 2011 at 2:12 PM
    TexasTacoma37
    Another example two outlets producing the exact same sound would be: is dual exhaust any louder than single exhaust because there are two pipes producing the sound instead of one?
  6. Sep 18, 2011 at 2:38 PM
    TexasTacoma37
    Ah, you are right about them not being the same horn. I didn't take that into consideration.
  7. Sep 18, 2011 at 2:55 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    It should make a difference. 50,000 people yelling in a stadium can be heard miles away while just one person would never be heard. I say go for it OP if anything the sound will travel farther.
  8. Sep 18, 2011 at 3:02 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
  9. Sep 18, 2011 at 3:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You can splice into the existing horn wiring, but it may blow the fuse. I have done it on another vehicle. Worked a couple of times, then blew the fuse. I rewired it with a relay after that. Horns actually pull a little bit of current.
  10. Sep 18, 2011 at 4:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    A second horn (or third in this case) will not "double the sound". You might see a 3 Db increase under the best conditions. To double the perceived loudness, which would be roughly a 10 Db increase, you would need ten times the power out put.
  11. Sep 18, 2011 at 4:39 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I did this on my Corolla with two lo tone and one hi tone horns from older volkswagens, they sound much better and deeper than the original. They're are also noticably louder, but not anywhere close to double or triple. I removed the OEM horn in my case and used the original wire to control a relay that feeds the "new" horns.
    I have a nice, deep trumpet air horn for the Taco when I eventually get air rigged up.
  12. Sep 18, 2011 at 4:46 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    I cut the power to the factory horns and ran it to a two way switch. Then The wires from the horns to the switch. I can switch between the horns I want and it was a very simple install.
  13. Sep 18, 2011 at 4:52 PM
    Fisheez
    Fisheez Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    just disconnect the stock horns and install the new ones using those wires. If the new horns are louder than the stock, no reason to keep em in.
    If your going for a nice loud sound go with the Hella Supertones, heard nothing but good with those.
    If your going for "waking the dead" loud, get a compressor, tank, and some airchimes, that'll get peoples attention.
  14. Sep 18, 2011 at 5:19 PM
    packfan88
    Acworth, GA
    i have different horns
  15. Sep 18, 2011 at 5:23 PM
    packfan88
    Acworth, GA
    i clicked on a few videos of those "Hella Supertones" ....maybe its me, but I dont like the way they sound.
  16. Sep 18, 2011 at 5:26 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    Are these new horns louder than stock?
  17. Sep 18, 2011 at 5:28 PM
    TexasTacoma37
    Supertones 118 db :cool:
  18. Sep 18, 2011 at 5:29 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    What the hell? Who said you can post intelligent articulate things? This is crap? Help Help! Hacked Account! Ben's MIA!
  19. Sep 18, 2011 at 5:30 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I installed a extra set of horns in almost the same location of the factory ones, just on the passenger side, the mounting bracket works as the ground, and i jumped power straight off the factory horn wire. I did have to increase fuse size due to the extra draw from the new horns, kept blowing the factory size. But i havent had any problems since, most ppl tend to jump back a hair when i blow them if they are in front of my truck.
  20. Sep 18, 2011 at 5:31 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    Yea that's better than stock..
    i think these are the ones he's talking about;
    Claims they are 135dB's.. hmm
