can you transfer old tires to new rims?
Discussion in 'Wheels & Tires' started by TacomaGus, Jan 30, 2010.
  1. Jan 30, 2010 at 11:40 AM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i was thinking about getting some after market wheels but i want to keep the tires i have now, i was just wondering if a tire place could simply transfer your current tires to the new rim since i plan to stay at 16in and my tires are great in the snow
    also i don't understand what the back spacing or offset measurements mean?
  2. Jan 30, 2010 at 11:52 AM
    TacomaGus
    Gus
    Morgantown, WV
    so i would have to get seperate wheel spacers as well?
  3. Jan 30, 2010 at 11:53 AM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    you shouldn't as long as you stay with in the same rim size and tire size
  4. Jan 30, 2010 at 11:58 AM
    TacomaGus
    Gus
    Morgantown, WV
    i have 265/70 r16 tires on the stock rims right now and i plan to keep the tires just transfer them to a 16in aftermarket rim which i understand now should be a problem but i still don't understand what the backspacing and offset measurements mean or if i would have to get anything else to make the rim fit on the truck...
  5. Jan 30, 2010 at 1:19 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    What brand/model of tire is it? What is the width of your new rim? If you have this info, check the tire specs at www.tirerack.com. Look for 265/70/16 row and the column RIM WIDTH RANGE. If the width falls within that range, then you can use that rim.
    Example:
    http://www.tirerack.com/tires/Spec....GTTAOWL&tirePageLocQty=&partnum=67R6RUGTTAOWL
    As for the backspacing or offset, that's a different question. If you want your tire to stick out a little bit, get a lower backspacing than your stock rim. But, you will have the risk of rubbing to the wheel wells when turning. Small lift or trimming will solve it.
    Search the internet. There are tons of information about backspacing and offset. Or you post the rim that you are eyeing for, so people can reply whether they will fit or not, or what modification that's needed.
  6. Jan 31, 2010 at 10:13 AM
    TacomaGus
    Gus
    Morgantown, WV
    i am thinking of going with the pro comp 7089 16in. Not sure if i would need a hub centric ones or not though. and thanks for clearing up the back spacing question
  7. Jan 31, 2010 at 10:16 AM
    TacomaGus
    Gus
    Morgantown, WV
    and you can get the rim in either 8 or 10in width so i would have to go with the 8in. Its all coming together now haha
    also i have the billy's in front set at 2.5in so would i even have to worry about rubbing with a little more backspacing?
  8. Jan 31, 2010 at 6:37 PM
    TacomaGus
    Gus
    Morgantown, WV
  9. Jan 31, 2010 at 7:12 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    There shouldn't be. I suggest that you stay no less than 4.5" backspacing.
    Most are running 16x8 4.5" backspacing or 0 offset.
  10. Jan 31, 2010 at 7:23 PM
    TacomaGus
    Gus
    Morgantown, WV
    so would that make my tires stick out a little more than stock? i like that look but only to a certain degree
  11. Jan 31, 2010 at 7:28 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    A little.
    Edit: I deleted the photos cuz it wouldn't help you since it's a 2nd gen.
  12. Jan 31, 2010 at 7:32 PM
    TacomaGus
    Gus
    Morgantown, WV
    so there is no way i could go to like 4.0 back spacing or a little less than 4.5 without having problems?
    thanks for all your help DTacoms i am a newb at this stuff
  13. Jan 31, 2010 at 7:39 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Some are running 4" BS. I suggest that you go the build section to look at the rigs or do some search. Or create another thread asking for pictures of 1st gen with 2.5" lift and stock tires. Ask them to include the wheel size and BS. Good luck.
  14. Jan 31, 2010 at 7:45 PM
    99tacoma
    99tacoma New Member
    Nick
    Mississippi
    99 Tacoma Ext. Cab SR5 3.4L
    Whenever you get ready to switch wheels, make SURE the tire shop uses bead lube when they dismount the tires and also when they remount the tires. If they don't use bead lube they could damage the bead of the tire and then it's no good, and of course you wouldn't know until you have a tire failure. Manufacturer's warranties do not cover demount/mount damage. I see this way too often in the tire industry.
  15. Jan 31, 2010 at 8:01 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Yeah they can but they will charge you to take the tire off and then put it back on. I thought about doing this but then I just decided to wait till I get the tires and wheels.
