canadian tacoma options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by simooner, Apr 8, 2007.
  1. Apr 8, 2007 at 6:41 AM
    simooner
    simooner [OP] Member
    newcastle ontario
    06 trd sport 4x4
    k+n cai readylift spacer kit with aal
    from pricing a tacoma in canada the packages only come in the sport towing package with a limited slip rear end. idid not see a trd offroad pkg with a locker, can you only get the one pckg up here in canada and how do people like the limited slip compared to the locker. thanks in advance for all answers
  2. Apr 8, 2007 at 7:54 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    I've seen TRD Offroads in Canada, but they appear to be either an 05 or 06 model. You could try asking the dealer if it's possible to special order one, but you may have a bit of a wait time before they recieve it.
    As for the locker vs limited slip, if this will primarily be a street truck you'll want the LSD and if you're looking at seriously offroading it you'll want the locker.
    My opinion is that LSD is far more useful for street performance. The truck launches harder from a standstill and you don't have to worry about having one wheel spinning on slick pavement, loose gravel or ice until you finally inch far enough forward to get decent traction like you would with an open diff (and the locking diff is an open diff when unlocked). In these cases an LSD is useful because it will transfers power to the wheel with the most traction, whereas an unlocked/open diff will transfer power to the wheel with the least. Also, a locker is pretty much useless in these situations because you're not going to drive around on the street with the locker engaged, and by the time you do engage it you could've inched your way forward enough that you won't need it anyway.
    An LSD is also useful for towing, particularily if you tow a heavy boat and want to pull it back up a wet launch. A locker will also help you get back up the ramp but it's not as useful for general towing since you can't drive around with your diff locked.
    As for offroad performance, a locker will be a big help if you're into rock crawling or mudding* (not much desert around Newcastle I'd imagine), since in the former you can frequently have one wheel off the ground and in the latter both wheels can have next to no traction even though both are burried in the ground. In these cases a locker has the advantage because it transfers equal power to both wheels regardless of traction (or lack thereof). Also, for technical offroading a locker is great because it gives you more control over your rear wheels, so you'll be able to better control your vehicles speed and grip over a harder obstical.
    So in the end it comes down to choosing the right tool for the job. If you want maximum street performance and will only do some mild offroading then a locker is a waste and you'll wish you had the added street performance of an LSD... but if you're planning on seriously offroading this truck then an LSD will only have you wishing you had the added offroad performance of a locker.
    * Note: By mudding I mean real mudding and not simply driving through dirty water... there is a difference... a big difference.
  3. Apr 12, 2007 at 10:37 AM
    natrlyst
    natrlyst Well-Known Member
    Actuall the off-road package is available in Canada but it is not available in a package with the four door model truck as they assume if you want such a long truck you wil not be using it for off-roading. It is only available in the two door versions. You are able to pay extra for the rear locker if you want it in place of the LSD. The TRD Sport package in Canada comes with all of the other goodies of the off-road package (skid plates etc.) but includes a limited slip rear in place of a locker and comes with sport tuned bilsien shocks in stead of off-road tuned shocks, ie, the shocks are the same but tuned differently for different uses.
    Hope that helps and if there is anything further you would like to know about the canadian packaging, pm me,
  4. Apr 12, 2007 at 1:37 PM
    ScreamingTaco
    The Sport also doesn't come with front a tow hook....f*ckers.
  5. Apr 16, 2007 at 12:11 PM
    natrlyst
    I agree but that is a very easy mend.
  6. Apr 16, 2007 at 1:58 PM
    ScreamingTaco
    $140CAD for a factory hook.
    You can also install the normal $10 hooks you can find at various automotive stores, but they don't bolt in strait so they twist when you pull and they stick out far enough that you can bend them on rocks and such.
  7. Jun 27, 2013 at 12:04 AM
    Seventy1
    Seventy1 Member
    Murray
    Canada
    TRD Sport
    I don't think the sport package includes the skid plate, it's extra$$.
  8. Jun 27, 2013 at 12:07 AM
    OZ-T
    OZ-T Half of you are clearly below average
    Peter North
    British Columbia
    This thread is 6 years old
  9. Jun 27, 2013 at 1:56 AM
    Seventy1
    Seventy1 Member
    Murray
    Canada
    TRD Sport
    I guess even if it's an old post, it didn't take long for someone to notice a comment on it.
  10. Jun 27, 2013 at 4:22 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Oz sees all......
