cant bleed brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greensystemsgo, Sep 2, 2011.
  1. Sep 2, 2011 at 5:05 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    so, i think my front right caliper is shot (stuck). BUT in an attempt to be doubly sure we tried bleeding the brakes. nothing. i dont mean like systems full of air, or liquid, just, nothing.
    gf's dad has no idea wtf the thing in the top left of this picture is, and neither do i, BUT, its break related. so ummmm ideas? will it inhibit me from bleeding the brakes doing the buddy method? why can i get any fluid even though the reservoir is full?
  2. Sep 2, 2011 at 6:41 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    stuck caliper means the brake piston is on the outward travel, and will not go in letting fluid travel from the caliper back to the master. When you drive it does the brake get really hot? if so then caliper is stuck trying to stop momentum.
  3. Sep 3, 2011 at 11:19 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    dunno about hot, but i used 3/4's of a tank going about 40 miles one day, and i had to use a rubber mallet to get the caliper off. we tried to pump bleed it and got nothing. resevoir was full, and they were working before is had everything off doing balljoints and what not.
  4. Sep 3, 2011 at 1:04 PM
    tacomazach
    tacomazach Well-Known Member
    Zach
    Mississippi
    01 doublecab 4x4
    The thing in the picture is just the antilock brake system
  5. Sep 3, 2011 at 1:06 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    hrm, that doesnt make bleeding brakes any different does it? ive just worked on older vehicles.
    im considering renting a pump from autozone.
  6. Sep 3, 2011 at 1:09 PM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    I wouldn't think it would have any bearing on bleeding. but i'm no brake expert
  7. Sep 3, 2011 at 1:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah but that ABS shit is tied to just about everything, I fucking hate it...
    Only thing I'd suggest is cracking every bleed zirk you can find only because I dont think that your entire brake system (lines to & from master cylinder) are independant of
    each other...
  8. Sep 3, 2011 at 1:12 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    so, gravity drain ever wheel, then close em, and start on rear right, rear left, front right, and finally front left? pump? all this junk started with a caliper acting up all of a sudden. grrr.
  9. Sep 3, 2011 at 3:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Fuck dude, I dunno. I get that pistons in calipers sieze sometimes but dont see how 1 froze up caliper (if in fact thats what it is) will hydro(fluid) lock the whole enchilada, take the whole fucking bleed screw off the troublemaking caliper , maybe plugged. Somewhere in your system it can be breached & normal bleeding can happen, you have hard pedal pressure with no loss ?
  10. Sep 3, 2011 at 3:28 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    hard to tell from the pic, but brake fluid is clear, yours looks like oil, invest in a turkey baster
    and change it
  11. Sep 3, 2011 at 3:37 PM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    The anti lock brake IS your problem. I have never bled the brake on the tacomas, but other cars I have done. Usually there is some procedure which some times requires special equipment (can't think of the name right now) to move the solenoid valves in the ABS system to the right position so that the you can bleed them. Unfortunately if you can't google it and find some good instructions you will have to take it to the dealer. The ABS system works by opening and closing these valves in that unit on the left based on the wheel sensors and brake pressure.
  12. Sep 3, 2011 at 5:00 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Valves are normally open only close to slow the breaking on the offending wheel when it's active. Bleeding the brakes won't help a stuck caliper.
  13. Sep 3, 2011 at 5:05 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    hardly the news i wanted :( ill have to tow it cause as of right now i have no brakes.
    aaaaand the my hubs are still pressed to tight.
  14. Sep 3, 2011 at 6:17 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
