Can't downshift into 1st gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bballrules, Jun 8, 2009.
  1. Feb 20, 2014 at 4:44 PM
    clcartwr
    clcartwr Member
    I've found with mine that if you hold slight pressure towards first gear while slowing down it will slide right in once you reach a certain speed. I've never been able to force it into first while moving unless I do this method even double clutching or rev matching doesn't seem to work...
  2. Feb 20, 2014 at 4:50 PM
    kylenotjon
    kylenotjon Well-Known Member
    Speed doesn't matter when shifting into 1st while rolling as long as you won't be spinning 10,000RPM when you get it into gear. How I do it: with clutch engaged, rev engine to approximate RPM 1st would be at if actually in gear, disengage clutch and shift to 1st, release clutch. If you're at the right RPM, the shifter will practically be sucked into gear.
  3. Feb 20, 2014 at 4:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    There is no way around it. Keep forcing/testing it and you will destroy the synchros then you will be rebuilding the transmission.
  4. Feb 20, 2014 at 5:09 PM
    gearcruncher
    Canadain bumper technician
    There is no electrical or mechanical lock out preventing you from selecting first gear .
    When you have the clutch mashed to the floor you separate the engine from the transmission , however you are also decelerating which means REVERSE powerflow .
    The rear tires drive the rear differential, The rear diff drives the driveshaft , the driveshaft drives the transmission output shaft . There is no way to remove the power of deceleration . If there was a clutch on the rear of the transmission removing powerflow , I am sure you could get first gear .
    HierAnarchy likes this.
  5. Feb 20, 2014 at 6:36 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    I see, good answer.
  6. Feb 20, 2014 at 6:50 PM
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    I let my buddy drive my 1 month old truck on a long road trip.
    We approach a traffic light and we're still going around 30 mph.
    I hear a godawful whining sound and look over and he's just mashing the shifter trying to force it into 1st.
    "DUDE!!! What the fuck are you doing??!?!?!"
    "what?, I have the clutch in"
    That was his last time driving my truck.
