Can't figure this hick-up out.
Discussion in '1st Gen. Tacomas (1995-2004)' started by PapaD, Jul 25, 2011.
  1. Jul 25, 2011 at 4:41 PM
    PapaD
    PapaD [OP] New Member
    Dennis
    north florida
    04 tacoma sr5 4wd w/ no mud flaps
    3" lift, K&N Air, Low profile tool box, pioneer sound, LTXs all around
    Running down the road with my foot on the Go Pedal my truck decides to take a break for a split second- like your lifting off of the Go Pedal. Seems to be showing up more here in the last couple of weeks. I commute 60 miles one way to work and this problem may happen 2 times- may happen 10 times. I get no check engine light- I get no codes on the scanner. Anybody got any ideas?
  2. Jul 25, 2011 at 4:45 PM
    98tacoma27
    Ben
    Not Beech Creek
    Could be a number of things; plug(s), injector(s), fuel filter, crank sensor................
    You can try to have it read for a code as one may be pending.
  3. Jul 25, 2011 at 5:05 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    throttle funny? no error code? TPS ! It is the thing the computer expects to change and can't monitor correctly. Of course it could be something odd, but that would be my first guess.
    cruxofthebisquit likes this.
  4. Jul 25, 2011 at 7:40 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I'm with Vinny, TPS!
    Do this:
    with truck off, pump gas pedal from 0 to 100% (full out, to full in) one hundred times.
    It's free, and it just might work. My TPS was acting crazy, i did this and it's been a couple of months since the problem last appeared. gdlk!
    *edit* the reason this works is that the type of sensor the TPS is has a sort of builit in cleaning mechanism, the 'known' cleaning method for this type of sensor in the electronics field is 100 cycles from stop to stop.
  5. Jul 25, 2011 at 9:46 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Nothing is more interesting than driving a truck with a dying TPS. I just replaced mine today. Very easy to do and not that expensive. Of course its best to diagnose before throwing money around. Do you have an ohm meter?
    TPS failure is common with tacomas
  6. Jul 26, 2011 at 1:39 AM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    96Taco - If i recall correctly, the TPS on every 1st gen besides 2003/2004's is cheap and easy... however, the TBW system on the newer models is stupidly expensive. pretty sure when i was looking every place i looked had me replacing the entire throttle body and it wasn't cheap. dumb. So i did the 100 pumps thing and have been fine ever since!
    I was so pissed when i found i couldn't just throw the cheap TPS replacement on it like all you other guys!
    jammer and Coolidge like this.
  7. Jul 26, 2011 at 1:57 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    so this works for what years and packages?????
    I have the same thing going on + a code telling its running to lean P0171 called toyota they said it may be 02 sensor on bank one so I bought the one they said still have to put it on.... but went and cleaned everthing out and then had a few other ones come out but they clear only one remaining it this P0171 so I think I'll pop it in tomorrow... but I still like to know about this 1oo pump thing... now back in the day this would flud the car .... i was always told it was a no..no.. so I have to ask is this ok to do... I have an 02 pre runner trd 3.4l.... if that helps any.....
    PLEASE SOMEONE LET ME KNOW IF THIS CAN BE DONE ON ME TRUCK BEFORE i PUT THESE SENSORS ON.....
  8. Jul 26, 2011 at 2:17 AM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    The original poster says he doesn't have any codes pending or thrown - so your issue may be different.
    To my knowledge the 2002 is not a 'throttle by wire' system so this will not work. My understanding (and limited experience) is it works on 2003/2004's due to the different style of TPS/TB
    It may flood if it was an old carburated engine, but our newer vehicles are fine. Just do it with the key off/out of the ignition.
    Try it - it's a possible free fix!
    Just let us know. For what it's worth, i did this and i only had 1 slight stumble in the next 10 miles but since then it's been fine! (i was having bad TPS problems every 15-30 miles prior)
    REV04 likes this.
  9. Jul 26, 2011 at 2:33 AM
    jesus
    jesus
    bakersfield
    thanks ... yea I saw that but it happen before the codes came up ... think I'll do one of the sensor tomorrow and see what happens...once more thanks...
  10. Jul 26, 2011 at 9:59 AM
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Thanks DoubleCabmn.. I never knew about the newer 2003/4 TPS system. I do not have the luxuary of owning such a nice new truck :p
  11. Jul 26, 2011 at 11:15 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    OP,
    What you are describing sounds like a missfire to me.
    Listen to Ben. Start with spark plugs.
  12. Jul 26, 2011 at 11:59 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This^
    x2, I just started getting a mis fire, finally got it to throw a code took it to my buddy's shop put it on code reader , came back as "Intermittant mis fire between cyl.1 & 2" Checking plugs & wires now...;)
  13. Jul 26, 2011 at 6:53 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I have an 04 SR5 V6 no code thrown but would feel a bad throttle lag 2 or three times a day on a 80 mile drive. checked the TPS using an ohm meter as per the service manual. It checked fine. I was sure it was the TPS, but as stated above the TPS replacement on an 04 is a 700 dollar fix with a new throttle body. I sprayed 1/2 of a bottle of sea foam down the throttle body while it was running and ran a bottle of sea foam in the gas tank twice. have not seen the problem for over two weeks. I think the 100 time push on the gas pedal is a good idea it will clean the potenometer in the TPS and I dont see what it could hurt to try. I posted my problem description on Tech Chat under title " Bad Throttle Lag" Good idea on the TPS pumping the pedal 100 times.
  14. Jul 26, 2011 at 8:52 PM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    "potenometer"
    That's the word i've been looking for!
  15. Jul 27, 2011 at 10:56 AM
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Funny thing about TPS which I still don't understand. My old one was throwing a code (p0710 by memory?), so I replaced it with another one from the wreckers just to trouble shoot. Code went away. Both TPS's ohm tested perfectly fine.
    The TPS that doesn't throw the code seems to rev surge when I apply the clutch. The TPS which throws the code drives perfect. Not smart enough to figure this all out yet
  16. Jul 28, 2011 at 12:38 PM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    I have a 2nd gen taco and I posted this thread and it almost sounds like the same problem. I changed spark plugs 2 montha ago and it's been running like a champ............until Monday!!!!
    Heres my post:
    The other day I took my AFE filter out of the CAI box. It's an oiled filter and I need to clean it (bad) and re-oil it. Anyways, I took it out and measured it (I ordered a Pro Dry S) and then put it back in and put the lid on the box. The next morning I hit the freeway and drove 12 miles and came to a stop light. As I took off in 1st all was good, when i put in the clutch it went sput sput, then I got it in 2nd and pushed the gas it sputtered a bit, then pushed in clutch and sput sput again then sputtered as i hit the gas. Then after that it ran like a fuckin champ!
    1: truck has never done this
    2: it happened morning after messing with air filter
    so............did i break some dust loose and it's sucking that shit in?
    Got the Pro Dry S coming Friday....hope that solves it. Then I will take this oiled AFE filter and clean it and reoil it and save for a backup.
    THANKS FOR ANY INPUT FELLOW TW MEMBERS!
  17. Jul 28, 2011 at 4:29 PM
    PapaD
    Dennis
    north florida
    My hat is off to ya DblCabMN! I did the 100 pumps and so far I have had no hickups in the last 300 miles. I'll keep ya'll posted as to how it goes.
    jeg0005, cruxofthebisquit and REV04 like this.
  18. Jul 28, 2011 at 4:48 PM
    Oregon TRD
    Ross
    2005 Mall Krawler
    I just did this to my 05. We will see I guess.
  19. Oct 5, 2014 at 4:42 PM
    squrrrlygurl
    squrrrlygurl Member
    Oakland, CA
    2003 4x4 SR5 DeChromed
    Debadged, Black Trim
    I just had the same problem with the hesitation at 1500-2000 RPM!
    I scoured the forums and saw this quick fix and it totally worked!!!
    thanks so much! seems like people go to the length of buying a new throttle body to fix this, after replacing fuel system parts and MAFs!
    thanks again!!!!
    REV04 likes this.
  20. Oct 5, 2014 at 4:57 PM
    little red
    little red Well-Known Member
    Central GA
    PreRunner SR5
    If you are one of those who drives until the fuel fill light comes on, it could be the fuel pump getting ready to bite the dust. Keeping it submerged in fuel inside the tank helps it run cooler. I never let mine get below 1/4 tank for that reason. Just a guess.
