Can't get the spindle off the freaking uca!
Discussion in 'Suspension' started by cgrove04, Aug 12, 2010.
  1. Aug 12, 2010 at 9:36 PM
    cgrove04
    cgrove04 [OP] 2010 tacoma v6 fox's
    Cory
    Richmond
    '10 trd sport v6 tacoma, fox's, ap bump, 33's
    Seriously I've beat everywhere on the freaking thing with a hammer, I'm replacing the factory uca with new tc uca's and IT WILL NOT BUDGE. FOR The love of god help
  2. Aug 12, 2010 at 9:38 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Hit it harder. Don't be afraid, it won't break.
  3. Aug 12, 2010 at 9:41 PM
    cgrove04
    Cory
    Richmond
    So where exactly is the best place to hit this thing, i have a 2010 taco sport. Also do i need to do any lifting with it b4 i knock it out? I seriously just bent a near 1 inch thick rod trying to pry it off. OMG !!!!!! GOT IT ,,I,, POS THINGS
  4. Aug 12, 2010 at 9:44 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    beat down on the top of the UCA, right about the bolt that goes down thru the spindle
  5. Aug 12, 2010 at 9:45 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Lifting the UCA or truck? The truck should be on jackstands..If you are talking about the UCA than I would say no, I didn't but it could help if it is having a hard time budging. When I did it, I hit it on the side of the spindle and the vibrations cause the two parts to dislodge from each other.
  6. Aug 12, 2010 at 9:45 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Edit: Nice, just saw you got it.
  7. Aug 12, 2010 at 9:54 PM
    cgrove04
    Cory
    Richmond
    2nd one off in a breeze, LESSON LEARNED, hit it from the bottom bolt
  8. Aug 13, 2010 at 9:31 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Oh if Chris was here he would say to never hit the bolt :eek: it could mess up the threads. There is a flat side on the top of the spindle facing the front of the truck, I few well placed sharp hits with a hamer and mine just pop out. But I'm gald you got yours taken car of; in the future try hitting it there though, to avoid messing up your threads. :D
  9. Aug 13, 2010 at 3:39 PM
    cgrove04
    Cory
    Richmond
    ya i was a lil worried but you don't keep that bolt if your replacing it do ya? I haven't installed the new uca yet so havent look over the directions. Cause if you do one of my nuts may be screwed
  10. Aug 13, 2010 at 3:42 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Never Never Never hit the bolt or ball joint in any way. there is a flat spot on the spindle above where the bolt comes through for the sway bar. Hit it there with short sharp blows. It will eventually break loose. If that fails then you need a proper ball joint separator.
  11. Aug 13, 2010 at 3:44 PM
    cgrove04
    Cory
    Richmond
    sorry new to this and tried about everything when it wouldn't come off
  12. Aug 13, 2010 at 3:46 PM
    PreRunnerSeth
    Apex, NC
    it can take a few blows. a proper ball joint separator is not that expensive either. i would say like $40 for a two size set, you dont want the pickle fork type they will damage the grease boot on the ball joint. Im used to california trucks. They tend to come apart a little easier.
  13. Aug 13, 2010 at 3:46 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Use your bottle jack and place it between the Lower Arm and the Upper Arm, and crank the jack up. then hit it.
  14. Aug 13, 2010 at 3:47 PM
    cgrove04
    Cory
    Richmond
    didn't think about that one, and ya next time i do it I'm gettin the proper separator
  15. Aug 13, 2010 at 4:48 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Did it work?
  16. Aug 13, 2010 at 4:53 PM
    cgrove04
    Cory
    Richmond
    already got it out early by beatin up on the nut, but next time (hopefully a long time from now) i will try the new ideas
