Can't loosen bolt on timing chain gear; Left hand treads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jadecuir, Nov 14, 2009.
  1. Nov 14, 2009 at 9:51 AM
    jadecuir
    jadecuir [OP] Member
    Salinas, CA
    4WD, 4 cyl
    I'm trying to pull the cylinder head on my 2003 2.7 liter. The bolt holding the timing gear to the intake cam is mondo tight. could it be left hand threads? Anyone done this before?
  2. Nov 14, 2009 at 10:33 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Hopefully you have an FSM and if not go get one.
  3. Nov 14, 2009 at 10:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No left hand threads. Maybe this will help?
  4. Nov 14, 2009 at 12:10 PM
    jadecuir
    Salinas, CA
    4WD, 4 cyl
    I got it loose. I put a bronze dowel thru one of the holes in the gear, so that the dowel rested on the head surface. Broke loose easily. Trying to break it loose holding the camshaft hex with a wrench was just impossible.
  5. Dec 29, 2009 at 7:33 PM
    mbtech208
    mbtech208 Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    It is super tight. I'm in the middle of doing the head gasket on mine, and I had to put a 2x4 between the wrench and the fender wall to hold the cam in place.
  6. Nov 14, 2010 at 7:13 PM
    tacopyro
    tacopyro Forever learning...
    SoCal
    01 Taco Pre SR5 V6 - 4WD
    Roll n Lock Cover and Stainless Step sides. New Mods. AFE Air Filter, PS Mag-Filter, Bilstein HD rear and 5100s Front. Michelins LTX MS2. Taurus E-Fan with FK50. Tundra Brake Upgrade. External Tranny Cooler. HO-Alt CS144 Mod, OMD Leaf Springs. Bull Bar. 4WD VF3AM Transfer Case, ADD/Manual Hubs. Supercharger with URD 7th injector. 4wd conversion complete Future Mods. rear sway bar, box the rear frame. I Love my Taco!
    Hi all. I know the thread is old but I'm desperate. My 2.7L gave up the gasket and I'm doing the same right now. but i've spent 3 hours on that timing gear bolt and nothing i do would dislodge it. i have a 1/2" socket wrench with 18" arm that i used and it wont budge. i have even used a 4 foot long pipe to augment my moment arm action but it still wont budge... I'm afraid of actually making it worse if i force it. i might break something...
    any tips on making it move? heat it up? cool it down? just keep at it till it moves?
    i checked the FSM and it only uses 54ft-lbs. not that bad but i'm sure i'm already at least 150ft-lbs but it still wont budge!
    would appreciate any tips. Thank You!!
  7. Nov 14, 2010 at 7:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  8. Nov 14, 2010 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Edit....I was thinking crank pully...
  9. Nov 14, 2010 at 10:11 PM
    tacopyro
    SoCal
    Thanks for the bump Trey and Chris... Hoping someone can give me some tips or pics if i were to do the 2x4 idea? dunno how much force the head can take before it breaks...
  10. Nov 15, 2010 at 5:28 AM
    Cb2589
    Cb2589 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    Hmm, I don't think I'd heat it up. No left hand threads, but I took mine off with a 3/8 impact gun. If that doesn't work you might try a 1/2 impact? lol...
  11. Nov 15, 2010 at 7:39 AM
    jadecuir
    Salinas, CA
    4WD, 4 cyl
    See the 11/14/2009 post: I got it loose. I put a bronze dowel thru one of the holes in the gear, so that the dowel rested on the head surface. Broke loose easily. Trying to break it loose holding the camshaft hex with a wrench was just impossible. You could use a 3/8" socket extension. Just put something between it and the aluminum head surface ( I used a steel ruler) so you don't dent the aluminum.
    By the way, visual inspection of my cyl hd found cracks between the valve seats and spark plug hole on several cylinders. Had to replace it. Odessa Head in florida sells new aftermarket heads with used cam/lifters, all adjusted, for about $300 on Ebay.
  12. Nov 15, 2010 at 8:26 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I think he means Air Impact gun, an air ratchet is a wimpy tool. A good 1/2" or 3/4" one will take it apart with no holdback on the pulley.
  13. Nov 15, 2010 at 8:43 AM
    Isthatahemi
    TRD OFF ROAD
  14. Nov 15, 2010 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Easy man...He's pointing out an Air ratchet is a totally different tool. Air ratchets are fine for bolts that arent torqued down hard, but an 1/2" standard ratchet will give more torque to the bolt......
  15. Nov 15, 2010 at 2:45 PM
    Cb2589
    Corey
    VA
    There isn't a big difference haha I just used a gun though. I stopped using an air ratchet on the real tight stuff cause it jerks your arm whichever way it wants to go if it won't break it loose. Then you'll be pissed cause your knuckles are bloody.....lol
  16. Nov 16, 2010 at 12:36 AM
    tacopyro
    SoCal
    Thank You Everyone for your suggestions!!!
    @Cab4You26: i only have a cordless Ryobi Impact Tool. I dont think its strong enough tho to do the job.
    @Jadecuir: Yea, I saw odessa on ebay just tonight before i saw this post. I guess I'll just crank up the muscles til it gives and if it cracks, get that one instead. Odessas price is now at 375 tho and you got to send back the core...
    @Krookz and @IsThataHemi. All Valid Suggestions. Peace guys! and Thank You!
    I'll do the 4 ft pipe again and this time not hold back. if it breaks. I'll get the one from Odessa, if not. then we're good. :)
    In the meantime, I think I'll add a impact tool to my list of gotta get tools.
    Thanks Again!
  17. Nov 16, 2010 at 6:46 PM
    Avsguy33
    Avsguy33 Well-Known Member
    Air tools are the best tools in your garage if you plan on doing any automotive work.
  18. Nov 16, 2010 at 9:48 PM
    tacopyro
    SoCal
    Thanks to everyone's suggestions. by far, i've analyze the problem and there were several issues. first was the moving cam, when i put on the muscles, it also rotates. next was the slipping adjustable wrench. when the cam turns, the wrench starts slipping out. i had a wood jammed against it so it wont move much but even with the wood against the wall. it still slips. so finally. i used my 8" 1/2 extension through the timing gear and it stopped it long enough that i was able to actually move it! hopefully that didnt do any damage.
    the only caveat would be is if the head cracked first... then i would have just bought an Odessa head.
    So for Future reference... here are some pics.
    [​IMG][​IMG]
  19. Nov 16, 2010 at 10:41 PM
    ywen
    ywen Well-Known Member
    attach a breaker bar onto the bolt, brace the bar against something solid like the frame of the truck, crank the engine and it will get loosened.
    edit: oops thought you were servicing the chain.. nevermind the above
  20. Nov 17, 2010 at 5:32 AM
    Cb2589
    Corey
    VA
    Glad to see you finally got it off.
    Take some pictures as you go, I'm thinking about pulling the head on my truck and putting a new one on. Pictures and a description would be a good help for anyone trying to do this later on.
