Can't loosen bolt on timing chain gear; Left hand treads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jadecuir, Nov 14, 2009.
  1. Nov 30, 2010 at 7:31 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    :confused:
    Just straightening thing out, relax.
    AND
    Not all impact driver's are air. Very good electrical Impact Drivers are available. They make more sense if you do not own a compressor.
  2. Nov 30, 2010 at 8:26 PM
    ywen
    ywen Well-Known Member
    owned and check mate!
  3. Dec 1, 2010 at 9:09 PM
    Isthatahemi
    TRD OFF ROAD
    I don't mean to be repetitive, but a 3/4" Air or Electric Impact Driver, would have this apart like butter, without risking cracking anything. You likely would not even need a holdback!
  4. Dec 1, 2010 at 10:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Like Chris, I thought you were talking about the lower pulley bolt which is always a first class mofo' But in any case the bolt you refer to would respond favorably to an impact either air or electric will do, its the quick "snap" of the impact that'll loosen things up, not the 6ft length of pipe you'll need for the pulley bolt ,lol:D
    & hopefully the "snap" will be the bolt coming loose & not the bolt shearing off....:eek::eek::eek:
    just make sure of the direction of the impact before using it, I know this is a "no brainer" but it is something that gets overlooked, I know I've done it(snapped bolts in half) as others have too I'm sure .. (its just the pain of admitting it that hurts)
  5. Dec 3, 2010 at 1:24 AM
    tacopyro
    tacopyro Forever learning...
    SoCal
    01 Taco Pre SR5 V6 - 4WD
    Roll n Lock Cover and Stainless Step sides. New Mods. AFE Air Filter, PS Mag-Filter, Bilstein HD rear and 5100s Front. Michelins LTX MS2. Taurus E-Fan with FK50. Tundra Brake Upgrade. External Tranny Cooler. HO-Alt CS144 Mod, OMD Leaf Springs. Bull Bar. 4WD VF3AM Transfer Case, ADD/Manual Hubs. Supercharger with URD 7th injector. 4wd conversion complete Future Mods. rear sway bar, box the rear frame. I Love my Taco!
    @isthatahemi: I had a Ryobi 18v Ratchet i wanted to try it with during that time but i couldnt due to space issues. it would mean a bigger job since i would have to remove the fan and the radiator to access it.
    @cab4you26: Sorry i didnt get to those pics on time for you. i saw in another post you already done it. but still noisy you said.
  6. Dec 3, 2010 at 8:01 AM
    Cb2589
    Cb2589 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    @tacopyro: Yes I did, although I never pulled the head on mine to do that.
  7. Dec 3, 2010 at 3:27 PM
    Isthatahemi
    TRD OFF ROAD
    I assume you meant an Impact, as a ratchet will not help. An 18 volt Impact will not help either as they only put out around 60 ft/lbs. A good 1/2" Air Impact will put out 250ish ft/lbs, and a 3/4" one will do around 500 - 600 ft/ lbs. That is the one you need. Don't waste you time clearing room for an Impact. if you have anything less than a 3/4". Consider renting one, it will remove the bolt in seconds.
  8. Dec 3, 2010 at 3:38 PM
    Cb2589
    Corey
    VA
    a 3/4in. to pull that break that bolt? no way. that's a little much if you ask me
    I use a 1/2in. impact with over 600 lb/ft breaking torque almost every day.
  9. Dec 3, 2010 at 8:23 PM
    Isthatahemi
    TRD OFF ROAD
    That must be an expensive 1/2" Impact to be belting out 600 ft/lbs! Or a not expensive one that had some wild numbers on the box.....
    Remember, you will only get the peak torque through a short, large diameter air line, and no extentions or wobbles.
  10. Dec 3, 2010 at 8:59 PM
    Cb2589
    Corey
    VA
    LoL yeah SnapOn. Snap on has a 3/8in. impact that has like 500 lb/ft break away torque... Those aren't mine though I don't have money for the expensive stuff! I have a $50 Kobalt 3/8 that gets it done just fine. :D
  11. Oct 14, 2014 at 7:41 PM
    GrapplerX
    GrapplerX Member
    E
    South OC
    2020 Tacoma, 2001 Tacoma Prerunner, 2000 4Runner
    Bringing this old thread in case someone else runs into this issue. I used my air impact wrench on the bolt and it did nothing, so I was done for the night so I just sprayed some PB Blaster on the cam bolts (also did this to the exhaust bolts the night prior to me working on the truck). Next day it came off pretty easy with the impact wrench, so this stuff worked pretty good.
  12. Oct 14, 2014 at 7:49 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    a bit late to the party but bolts like this need to be broken loose by shock so an impact gun or a box end wrench hit briskly with a hammer makes short quick work to break them loose, even when you cant hold them solidly in position.
    lawn mowers and motorcycle engines are famous for these bolts that seam welded on and wont break loose
