Can't read radio screen in daylight. any way to brighten?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wildwood man, May 1, 2017.
  1. May 1, 2017 at 10:27 AM
    wildwood man
    wildwood man [OP] Member
    larry
    17 sr5 access in barcelona red v6
    What can you do to brighten screen in daylight can't even see backup camera.
  2. May 1, 2017 at 10:55 AM
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    There is an adjustment under the settings on the radio head.
  3. May 1, 2017 at 11:00 AM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Yeah that's under your general settings or display settings on the radio. I'm sure the manual gives step-by-step instructions for navigating through menus on the head unit if you can't find it.
  4. May 1, 2017 at 11:50 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Turn your head lights and fog lights off.
    SilverBulletII and whatstcp like this.
  5. May 1, 2017 at 11:52 AM
    taco terror
    USA
    Yeah that is another good point, if you have your headlights on in the daytime you can adjust the cluster brightness all the way up so the head unit isn't dimmed.
  6. May 2, 2017 at 5:44 AM
    wildwood man
    larry
    Thanks guys. Got it adjusted what a difference
    Reagan2791 likes this.
  7. May 2, 2017 at 1:37 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  8. May 2, 2017 at 4:03 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Is there a way to have the "daytime" Nav map run when your lights are on? My map turns blackish when it runs at night. I would much prefer it remain bluish like it does during the day. I realize this is to keep glare down in the driver's area but I'd still like it to be bright blue when I am driving at night!
  9. Feb 10, 2019 at 1:50 PM
    tjeffrey4
    tjeffrey4 New Member
    2016 Tacoma Sport
    None
    Well gee, in our county/state it's against the law to NOT have your lights on if it's raining or snowing....any suggestions now?
  10. Feb 10, 2019 at 4:08 PM
    bamajoey
    bamajoey Well-Known Member
    Pensacola Florida
    2018 red Tacoma SR5 double cab
    None
    I just wish there was a way to turn ALL the instrument lights off at night.
  11. Feb 10, 2019 at 4:16 PM
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Read all of the replies before you post?
  12. Jul 13, 2019 at 5:36 AM
    rarewolf
    rarewolf Member
    Michael
    14 Tacoma V6 6-spd AC TRD/OR
    I found the setting!
    You have to first turn your parking or headlights on!
    Setup=>Display=>(enable) Daytime
  13. Jul 13, 2019 at 5:48 AM
    Ionnaeus
    Ionnaeus Well-Known Member
    Jon
    Tennessee
    2016 Quicksand SR5 DCSB
    Mine was too dim as well even though my windows are tinted. I can't imagine you could see a thing if your windows were untinted and it was sunny out. Thanks for the info
    rarewolf likes this.
