Can't remove splash guard without removing flare, also the opposite?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Dec 25, 2019.
  1. Dec 25, 2019 at 1:05 AM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    This doesn't make much sense I know, but I am changing out fender flares and want to remove them without breaking all the plastic tabs on the flare itself (happens every time). Many posts on this sub say to remove the plastic splash shield/fender liner to gain access to the back of the fender to pop out the clips, but...... it's impossible to get out the grommets that are under the flare without taking that off first. So what is the proper procedure? Does anyone have the Factory Service Manual to see what they recommend?
    Also, Merry Xmas TW.
  2. Dec 26, 2019 at 12:43 AM
    drewskie
    Drew
    Burbank, CA.
  3. Dec 26, 2019 at 3:12 AM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Could you post a picture?
    I took off my front flaps a few years ago when I did my lift and upsized tires and I don’t remember taking off the flares to do so.
  4. Dec 26, 2019 at 4:53 AM
    DG92071
    DG92071 Well-Known Member
    He's not referring to the mud flap. He is referring to the plastic fender flare and the plastic inner fender.
    Destroy the inner fender clips to gain access to the back of the fender flare to keep from destroying the fender flare and its clips.
  5. Dec 26, 2019 at 5:16 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  6. Dec 26, 2019 at 11:19 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    The passenger side front flare on my truck had all but like 2 clips broken on it from the PO doing a snorkel install.
    I had to pull the flare and inner fender to get leaves and crap out of there (cowl was not draining), ordered those clips before I did it. Good thing I did because I broke the last couple of clips taking the flare off.
    The Amazon ones fit perfectly.
    DG92071 likes this.
  7. Dec 27, 2019 at 12:53 AM
    drewskie
    Drew
    Burbank, CA.
    Did this today, ripped and cut and pulled the shit out of the 10 or so clips, then removed the liner. Somehow the stupid flare tabs are still broken.
  8. Dec 27, 2019 at 12:55 AM
    drewskie
    Drew
    Burbank, CA.
    I actually have like 50 of the clips, I am trying to avoid ripping the tabs off the actual flare, since they are not able to be replaced and are incredibly easy to tear off.
    DG92071 likes this.
  9. Dec 27, 2019 at 12:55 AM
    drewskie
    Drew
    Burbank, CA.
    Did you not break any of the flare tabs?
  10. Dec 27, 2019 at 4:57 AM
    DG92071
    Uhg that sucks. Those tabs on the flares themselves are so thin!
    drewskie[QUOTED][OP] likes this.
  11. Dec 27, 2019 at 10:02 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Try starting on bottom 1st . Remove mud flaps then bolt on bottom of fender and one above mud flaps holding flares to fender .Had to pop bottom of all 4 flares and poped 1st 2 clips on bottom without breaking. Never tried popping rest since I didn't have to but can pull flare out enough to see next clip. Maybe can use interior trim removal tool to remove rest of clip. I will check tommorow . Still working on mine .
    drewskie[OP] likes this.
  12. Dec 28, 2019 at 2:23 AM
    drewskie
    Drew
    Burbank, CA.
    Taking out the fender liner is a giant pain in the ass, but once it's out, getting behind the flare to pop the clips out is much easier and doesn't risk breaking the cheap tabs.
    hemitruk[QUOTED] likes this.
  13. Dec 28, 2019 at 6:24 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    Total brain fart on my part.
    My bad!
    DG92071[QUOTED] likes this.
