Captain Ameritruck build and BS thread
Discussion in '3rd Gen. Builds (2016-2023)' started by CaptAmerica, Dec 15, 2015.
  1. Jan 30, 2016 at 2:31 PM
    #181
    CaptAmerica
    CaptAmerica [OP] Asphalt Avenger! TTC#13
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Ok, what to talk about first? How about the Toyota mudflaps. They could not be any simpler to install. They even come with 4 extra screws that tap into the plugs that hold the wheel wells in. Unscrew the existing screws, add mudflap, put the screws (+1) back in. Repeat 3 times. Done.
  2. Jan 30, 2016 at 2:36 PM
    #182
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I want DCSB TRDOR w/ 6spd MT in Quicksand ... damn you Cap. :laughing:
    CaptAmerica[OP] likes this.
  3. Jan 30, 2016 at 2:46 PM
    #183
    CaptAmerica
    Cap
    The weatherstripping was "fun." First I installed the cab rail seals. You need a T30 torx and some wrist muscle. Good thing I trained hard in my teens for the latter, and I just happened to have the former.
    Removed the cab rail (5 T30 torx) and cleaned it all. You can make out the gap at the far left.
    I cleaned everything with a mixture of Dawn and water, with about 20% alcohol thrown in for good measure.
    Carefully peel the backer off. It doesn't want to come - 3M adhesives work well. It's simply a thick foam sticker.
    I put th cab rail back on, and using that historic wrist strength got those torx back in. Toyota must torque those things within an inch of their lives - the instructions said 67 pounds. Holy hell!
    I cleaned everything back up, repositioned the cover, and tightened it down. From inside, you can see clearly that it's sealed.
    Cab rail done!
    EB Group and TinyTech626 like this.
  4. Jan 30, 2016 at 2:51 PM
    #184
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Looking great Cap! Does that cover fold up against the cab for use of the bed for tall items when necessary?
  5. Jan 30, 2016 at 2:53 PM
    #185
    CaptAmerica
    Cap
    The tailgate seal was also easy. I cleaned all surfaces, test fit the weatherstripping dry so I knew where my best close points were, and down it went.
    It's hard to notice, but the round edge of the weatherstripping is resting perfectly between the bed and the tailgate. Nothing is pinched.
    I did it in three pieces, which fir how the bed is laid out. The YouTube videos I saw were all for Chevys and Fords, and Homey don't play that.
    Starting with a clean area, I dry fit and measured the seals. Once I'd figured out where the best place to have the bulbous end rest, I put it down.
    When the tailgate closes the weatherstripping fills the gap.
    Time to break out the pressure washer. Tomorrow!
    EB Group and MQQSE like this.
  6. Jan 30, 2016 at 2:54 PM
    #186
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Props on the sandal/Jean mashup
  7. Jan 30, 2016 at 3:01 PM
    #187
    CaptAmerica
    Cap
    I can't talk you into getting a truck you don't want. Don't flick that booger on me!
    With the Extang SolidFold, only the first two sections flip back - the cab section is still held in place. Y brother's BakFlip on his F-150 does stand up against his cab for tall, full-bed items.
    However, unlike the BakFlip, the Extang takes all of 30 seconds to remove the entire cover. Unlatch the clips holding that first section in and "boom" - she's out. It is also easy to put back in place after you're done. The Extang also doesn't have drip rails and drain lines, and the BakFlip does.
    The BackFlip is flush though, and the Extang is about 7/8".
    My suggestion is to go with the one you like. I've seen the factory one (on short beds only) and it has the benefit of being cheaper than both the BakFlip and Extang. It has to be unscrewed to be removed, though, and sometimes it doesn't seal perfectly at the gate - there's definitely a knack for closing it.
    MQQSE[QUOTED] likes this.
  8. Jan 30, 2016 at 3:04 PM
    #188
    CaptAmerica
    Cap
    I didn't feel like wearing knee pads when putting the mud flaps on. I'm sure I looked like shit. When Lucy (queen puppy) and I ran out to Lowes a little while ago, I dropped back to shorts.
    The real WTF is 80 degrees at the end of January. Holy global warming, Batman, we need to take this El Niño kid out!
  9. Jan 30, 2016 at 3:42 PM
    #189
    TashcomerTexas
    You're telling me, we just got back from kayaking.
    Last week went from cold and windy to non stop rain, now 85 degrees tomorrow with a low of half that at 40.
    Texas weather.
  10. Jan 30, 2016 at 3:47 PM
    #190
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Not flicking boogers ... but I'm coming around to the look. Probably a couple years out in all reality, unless I lose my patience. I've got time to do research. :)
    Thanks for the cover info. :cool:
  11. Jan 30, 2016 at 4:01 PM
    #191
    CaptAmerica
    Cap
    :hattip:
  12. Jan 30, 2016 at 4:33 PM
    #192
    JennJenn
    JennJenn Remembering Rick ❤
    Jenn aka (dzzyneon)
    Boise, Idaho
    2021 Army Green Trd sport dclb!!~Sold~2008 Indigo ink TRD Sport DCLB!!
    :spy:
    MQQSE likes this.
  13. Jan 30, 2016 at 4:42 PM
    #193
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    IMOP the Gen 2 mud flaps with the "4X4" embossed on them are much nicer than the plain black ones on my Gen 3.
  14. Jan 30, 2016 at 4:42 PM
    #194
    CaptAmerica
    Cap
    So many suspicious characters around here!
    Are you suggesting that my pavement princess get (*gasp!*) dirty?
    MQQSE and JennJenn[QUOTED] like this.
  15. Jan 30, 2016 at 4:43 PM
    #195
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :hattip: Jenn :cool:
    JennJenn[QUOTED] likes this.
  16. Jan 30, 2016 at 4:43 PM
    #196
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Ewww not dirty!!!!
  17. Jan 30, 2016 at 4:44 PM
    #197
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Hiya sweets!
  18. Jan 30, 2016 at 4:44 PM
    #198
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :anonymous:
    JennJenn likes this.
  19. Jan 30, 2016 at 4:44 PM
    #199
    CaptAmerica
    Cap
    Worse!! That's like dirty's evil big brother that gives wedgies!!
    .劉煒 and JennJenn like this.
  20. Jan 30, 2016 at 4:44 PM
    #200
    JennJenn
    Jenn aka (dzzyneon)
    Boise, Idaho
    Sounds fun either way...;)
