car chirping
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Dec 22, 2009.
  1. Dec 22, 2009 at 8:23 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    For the past week or so my car has been chirping. It sounds like its coming from the transmission. It stops if i put very slight pressure on the clutch pedal. i changed my clutch about a month ago if that matters. any thoughts?
  2. Dec 22, 2009 at 8:30 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Sounds like it could be the throw out bearing.....
  3. Dec 22, 2009 at 8:30 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    It's the throw-out bearing. Seen it hundreds of times, but is it in your "car" or "truck?"
  4. Dec 22, 2009 at 8:30 PM
    dylandercole
    Dylan
    ya but i replaced the throwout bearing along with my clutch. It was brand new
  5. Dec 22, 2009 at 8:31 PM
    dylandercole
    Dylan
    truck. my apologies. and i jsut couldnt think it would be because i just replaced it
  6. Dec 22, 2009 at 8:32 PM
    cadman
    cadman Well-Known Member
    Pensacola, Florida
    TRD PreRunner
    what wasn't replaced with the clutch? i'm thnking the throw out bearing is the culprit.
  7. Dec 22, 2009 at 11:59 PM
    dylandercole
    Dylan
    the only thing not replaced was the flywheel. The pressure pad, clutch plate, throwout bearing and pilot bearing were all replaced
  8. Dec 23, 2009 at 7:00 AM
    carmellocafe
    KEVIN
    N. California
    No prob. Dylan. I hope you didn't take that the wrong way--Wasn't trying to sound like a smart-ass. Just didn't want your "truck's" feelings to get hurt. :)
    Man, I don't know, "chirping" is usually indicative of the throw-out bearing. The other thing you could check is the linkage to the clutch pedal I guess. It's not likely a brand new bearing would chirp, but I suppose it's not impossible either. Good luck. :thumbsup:
  9. Dec 23, 2009 at 10:18 AM
    dylandercole
    Dylan
    dont worry I was just messing too. yea im really hoping a brand new bearing wouldnt make noises. but thats what I was thinking too. could I have messed it up in anyway putting it on. (not that it matters im not opening that trranny back up anytime soon)
