Car solutions reverse anytime + front camera install
Discussion in 'Audio & Video' started by abidar, Apr 15, 2019.
  1. Nov 4, 2020 at 4:48 PM
    #441
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I didn't put mine behind the head unit, it fit below.
  2. Nov 5, 2020 at 5:48 AM
    #442
    IdeaMan
    IdeaMan Well-Known Member
    Jim
    Fresno, CA
    Barcelona Red 2018 Toyota Tacoma SR DCSB 4x4
    Eibach Pro Truck Lift, Icon RXT Leaf Springs, LT255/80R17 Toyo ATIII, Body Armor Hiline Bumper w/OZ LED Light bar and Smittybuilt X20 Synthetic Winch, TRD Pro Skid plate, Shrockworks Sliders/steps, bed mat, some interior storage accessories, cell phone mount, and blacked out emblems.
    That’s how mine fit too. It really was not that tight.
  3. Nov 5, 2020 at 5:26 PM
    #443
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    Random issue. System has been working flawlessly for the last year. Out of the blue, front camera stopped showing. I changed cameras and no image. Checked all connections, all good. I can hear the relay work when switching from front to back, etc. Theres power going to the camera (checked 12v on wire with RCA connector).
    I've checked pretty much everything and nothing has fixed it.
    Bonus question: kit has an extra rca labeled "rear cam". Since the OEM rear cam is being bypassed, would a 3rd camera work?
    Edit: I didn't try everything. New camera didn't match with old wiring for power. Made proper connections and it works again. I guess just changing cameras doesnt always apply.
    Cipher94 likes this.
  4. Nov 6, 2020 at 11:44 AM
    #444
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    "OEM rear cam is being bypassed" ???
    Don't you see the rear cam when you put the truck in reverse?
  5. Nov 7, 2020 at 10:09 AM
    #445
    S2KON2
    So Cal (SFV)
    Yes, I see the rear cam working both when in reverse and activated by steering wheel controls.
    What I meant to say by "bypassed" is probably piggyback. Since the oem camera is on the harness and not on a separate rca, can we use that left over rca for a 3rd camera?
  6. Nov 7, 2020 at 2:55 PM
    #446
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    No, because the OEM rear cam is connected through the harness wiring. There is no way to "select" a third camera for viewing.
  7. Nov 10, 2020 at 7:05 PM
    #447
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Hey so I got something similar happening to me. Except opposite.
    System was working no issues until back in August randomly disabled my back camera... Front camera would work, back camera the switch flips and you can hear it but the screen goes black. Ditto when reversing the screen is black again front camera works... I tried pulling out my wiring to look and figured out disconnecting everything made the rear camera function normally. So now here's the wiring catch. I didn't tweak any of my wires..
    However I never had a ground wire because my camera is wired directly to the battery, then the yellow av plug that goes through the firewall up to the module only has a positive wire connected to it, it doesn't have a negative. So I hadn't been running a ground anyways. If I were to run a ground would I connect it all the way to the battery negative?
    The companies support weren't helpful I was scolded for wrapping wires in electrical tape. Btw the electrical tape was around the outside of the crimps.. just to help support them. My modules blue light does come on, and it flashes when in use. But this has gotten sad since it worked so well before .
    Any ideas?
  8. Jan 13, 2021 at 1:50 AM
    #448
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Any issues with the camera mounted in front of the TSS like you did?
  9. Jan 14, 2021 at 9:21 AM
    #449
    horntac1
    horntac1 Well-Known Member
    Negative - All TSS function as expected.
  10. Jan 14, 2021 at 12:22 PM
    #450
    VaToy
    Parts Unknown
    Cool I mounted mine there and it's perfect! No issues.
    horntac1[QUOTED] likes this.
  11. Jan 26, 2021 at 10:55 AM
    #451
    Lht123
    Lht123 Active Member
    PNW
    2019 OR DCLB Cav Blue
    Installed this setup this weekend, now having an odd issue with my key fob - the fob won't lock or unlock the truck for 30 seconds or so after parking and shutting off the engine. Anyone experienced something similar? Any ideas?
  12. Jan 26, 2021 at 11:08 AM
    #452
    VaToy
    Parts Unknown
    I bet its your batter for the fob.
  13. Jan 26, 2021 at 11:59 AM
    #453
    Lht123
    PNW
    Thanks, I considered that but it works fine after that first 30 seconds or so and has the exact same behavior with the other fob.
  14. Jan 31, 2021 at 9:27 PM
    #454
    Maxf61
    Maxf61 New Member
    2017 Quicksand Tacoma 4x4 TRD Sport
    2" lift
    I installed the Car Solutions setup. It works great.
    I got confused when there wasn't n Rca connection from the stock rear camera...but that's somewhere inside the stock wire loom.
    The automatic switching was super useful when I plowed my church parking lot.
    markram and DES2009 like this.
  15. Feb 26, 2021 at 1:15 PM
    #455
    GONE FISHIN'
    GONE FISHIN' Well-Known Member
    northern front range CO
    21 ORAC
    anyoneknow if the CS setup is compatible with 2021 models (OR)? tried to extract from thread read butculdn't find successful instal on a 2020/21. ty
  16. Feb 26, 2021 at 5:20 PM
    #456
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    I believe that 2020 & 2021 have the Entune 3.0 stereo unlike my 2018 that has the Entune 2.0. I've read that there is an adapter harness to make this kit work for the 3.0 so check out their website for more info in the reviews. I saw a guy ask the same thing there & the company responded with a link to the adapter harness
    https://car-solutions.com/en/rfcc-ttg2-car-camera-control-system-for-toyota-touch-2-entune/
    GONE FISHIN'[QUOTED] likes this.
  17. Feb 26, 2021 at 6:21 PM
    #457
    GONE FISHIN'
    21 ORAC
    Hi MrBrooks and thank you kindly for your helpful repsonse, I found the comments and adapter you referred to and I have a good path to follow-up now. :)
  18. Feb 26, 2021 at 7:23 PM
    #458
    MrBrooks
    Midwest
    Excellent :thumbsup: The website should be updated to show for the 20/21's but it hasn't. I got mine on Amazon a couple of years ago & still works perfectly
  19. Feb 27, 2021 at 1:12 PM
    #459
    GONE FISHIN'
    21 ORAC
    I received a response from car solutions on new model years compatability with kit RFCC Car Camera Control System for Toyota Touch 2 CY17-19 / Entune 3.0 (ID: 894269). Bit different from their ID: 875000
    RFCC TTG2 Car Camera Control System for Toyota Touch 2/Entune that has been illustrated in some TW threadsthat has been illustrated in some TW threads- passing along in case anyone else was as confused as I - but it was read on a Friday nght after all. Ordered form car-solutions wonky web-site, currently 150 USD plus 20ish shipping. Hoping it helps with the steep crests frequently encountered when exploring Colorado high country.
    Sent: 27 February 2021
    To: 'sales@car-solutions.com', 'support@car-solutions.com'
    Subject: compatibility question
    Hello;
    I am wondering if the kit RFCC Car Camera Control System for Toyota Touch 2 CY17-19 / Entune 3.0 (ID 894269) is compatible with a 2021 Toyota Tacoma Offroad . I know Toyota limited Entune in some ways in very recent model years but suspect hardware is unaffected. Can you confirm kit is correct for 21 Tacoma ? Thank you.
    J.M. O’Donnell
    Hello Jake,
    Thank you for your request.
    Yes, we confirm that ID894269 will work for a 2021 Tacoma
    With best regards,
    Gregory, Car Solutions team
    Tel: +852 397 33 882
    Skype: gregory_car-solutions.com
    Technical Support: support@car-solutions.com
    Car Solutions
  20. Feb 27, 2021 at 1:16 PM
    #460
    GONE FISHIN'
    21 ORAC
    regarding previous post - real confirm willbe after install :)
