Car solutions reverse anytime + front camera install
Discussion in 'Audio & Video' started by abidar, Apr 15, 2019.
  1. Feb 4, 2022 at 9:11 AM
    #481
    TrailToy867
    TrailToy867 Member
    2013 trd off-road
    Blistein 6112/5160
    I’m guessing this only worked with the ABC harness and not the car solutions kit?
  2. Feb 4, 2022 at 11:36 AM
    #482
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Yes, he designed this for himself but also had made a few extra so I bought one. He is a genius. We have been working on a few other electronic design projects since then. The latest is a PCB that uses the MESO micro-switches for the TRD Pro shift knob and my illumination mod.
    MGMDesertTaco likes this.
  3. Feb 7, 2022 at 4:06 PM
    #483
    TrailToy867
    TrailToy867 Member
    2013 trd off-road
    Blistein 6112/5160
    Trying to figure out if any of these works for a 2013 with JBL entune headunit. Got the rfcc ttg1 but it has a 10 point non-JBL only connector. Pretty frustrating how the car solutions website shows incorrect connectors for both the ttg1 and ttg2. The pic on car solutions for ttg1 shows 12, 16 and 28 point connectors instead of the 10 point non-JBL (in place of the 12 point) I received. The ttg2 for this thread shows an 8 pin connector, but the website shows 24, 28 and 16 point connectors. Anyone else notice how the pictures and the actual wires aren’t identical?
  4. Mar 13, 2022 at 2:30 PM
    #484
    andagi808
    andagi808 Well-Known Member
    Hawaii
    2021 Black Tacoma TRD OR MT
    Having some issues with installing this. 2021 tacoma, got the most recent version that supports entune 3 and the nakita camera.
    Here's some pics of everything connected, but no picture (front or rear) pops up once the battery is connected and truck is turned on. What am i missing?
    Edit: had to turn DIP switch 3 off for it to work.
  5. Mar 13, 2022 at 7:45 PM
    #485
    kaptainsims
    kaptainsims Well-Known Member
    Sims
    2021 Tacoma TRD Offroad Double Cab 6 speed
    None yet
    Has anyone installed the oem camera onto a TRD off-road or sport?
  6. Mar 15, 2022 at 9:10 AM
    #486
    bd6675
    bd6675 Active Member
    I was hoping someone could help me with 2 requests:
    1) Anyone have any mounting ideas (with pictures) for the CS kit with a Nakita camera on a 2018 Tacoma Limited (stock grill)? I have seen posts in this thread by Tmaloy and Tullie D but was hoping there were other ideas out there.
    2) Anyone have any suggestions for getting the wires run through the firewall? I was hoping someone had some pictures of the entry point.
    Thanks in advance,
    bd6675
  7. Mar 15, 2022 at 9:27 AM
    #487
    oostroma
    oostroma (Boomer)
    Ontario
    re: firewall
    There is a big rubber grommet under the master brake cylinder.
    bd6675[QUOTED] likes this.
  8. Mar 15, 2022 at 9:43 AM
    #488
    Ford2YotaGuy
    Ford2YotaGuy Well-Known Member
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    I just installed this as well and have the same issue. Did you ever figure it out?
  9. Mar 15, 2022 at 10:32 AM
    #489
    oostroma
    oostroma (Boomer)
    Ontario
    Is there a possibility that the unit is drawing power which makes the ECU think the door is still open?
    Ford2YotaGuy[QUOTED] likes this.
  10. Mar 15, 2022 at 10:48 AM
    #490
    Ford2YotaGuy
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    That could be a possibility. If that were the case, how would you go about fixing that?
  11. Mar 15, 2022 at 10:50 AM
    #491
    oostroma
    oostroma (Boomer)
    Ontario
    Power the camera from a different fuse tap.
  12. Mar 15, 2022 at 10:52 AM
    #492
    Ford2YotaGuy
    Austin
    Fort Collins, CO
    2019 TRD Off Road
    Good to know, i'll check it out.
  13. Apr 3, 2022 at 11:50 AM
    #493
    bd6675
    I have a 2018 Tacoma limited with the correct CS module and the Nakita camera and I got it all hooked up and it worked perfectly fine immediately afterwards and then the front camera stopped displaying an image. I can hear the CS module switch between the front and stock rear camera and it displays the rear camera just fine. When I try to switch to the front camera I just get a black screen. Again, it worked for a few hours or so. I suspect it is an issue with the camera as opposed to the CS module but I am not sure. I have pulled everything apart again and made sure the wires and connectors were connected as instructed. I have the red trigger wire from the camera connected to the red trigger wire from the CS harness. Any ideas?
  14. Apr 3, 2022 at 1:00 PM
    #494
    oostroma
    oostroma (Boomer)
    Ontario
    Do you have anything to test the video output from the front camera only like an old small LCD TV?
  15. Apr 3, 2022 at 1:22 PM
    #495
    bd6675
    Thought about that.. unfortunately no.
  16. Apr 3, 2022 at 1:42 PM
    #496
    bd6675
    Actually, I do have a tv that has the red and white rca video inputs…could I plug the camera into either the red or white connector and get an image?
  17. Apr 3, 2022 at 1:53 PM
    #497
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    red and write(or black sometimes) are audio Right and Left
    yellow is composite video (same as these cameras)
    red green blue is component video
    just red and white is most likely audio out of the TV
  18. Apr 3, 2022 at 2:01 PM
    #498
    bd6675
    Yeah, I have red green blue and then the red and white pair…
  19. Apr 3, 2022 at 2:03 PM
    #499
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    you can try the green port but the image will be funky
  20. Apr 3, 2022 at 3:53 PM
    #500
    bd6675
    I will give it a try…all we care about is if it will display any image at all…thanks for the advice. I also purchased another camera (same one) to test various pieces in the chain to the CS module.
