Car solutions reverse anytime + front camera install
Discussion in 'Audio & Video' started by abidar, Apr 15, 2019.
  1. Jul 8, 2025 at 4:52 PM
    #521
    verruckt
    verruckt Member
    2023 Tacoma. Ordered hooked, RFCC powers up, double click "mode" works, no camera on display. Not even trying to show a camera at all. I mean if the camera is not hooked up, I expect to see a blank screen instead of a camera but I get not effect of any sort. Mine states on the box: RFCC Car Camera, Control System for Toyota Touch 2, CY17-CY19/Entune 3.0. Product ID: 894269. The harness is from Car Solutions with the RFCC. Any ideas what am I doing wrong? Thank you in advance for your time.
    PS When the RFCC is hooked up and I turn on the engine and switch to reverse, no camera either. Not a sign at all, the display stays as I didn't put on reverse at all. No change. Once I disconnect the RFCC, everything works normal.
  2. Jul 8, 2025 at 5:20 PM
    #522
    Bill_C
    Bill_C Member
    Bill
    Central Valley, CA
    2022 White TRD Offroad
    Two thoughts:
    First is to make sure you have the correct firmware for your vehicle. Email the company and they will send you the firmware package.
    Second, it might just not be compatible with your year. I tried it in my 2022 and it was super buggy even after the firmware update. Intermittent remote lock/unlock failure, delayed camera activation, etc. You might want to check with the company to see if they fixed the firmware for your year.
  3. Jul 8, 2025 at 5:22 PM
    #523
    sju350
    sju350 Well-Known Member
    Joe
    TN
    18 Tacoma TRD Smokin Edition
    Make sure the dip switch #3 is turned off on unit. If on, turn it off when the power is turned off on truck.
    eaglehawaii likes this.
  4. Jul 9, 2025 at 7:11 AM
    #524
    verruckt
    verruckt Member
    Vielen dank.
    That did it. By default switches #s 1, 2, and 3 are “on”. Switching switch # 3 to “off” did it. Everything works.
    Yurii from Car Solutions support was extremely responsive and answered me right away in an email and in WhatsApp, and let me know to turn off switch # 3 and give it a try again.
    Thank you for your advice and time. You really made a person smiling today!
  5. Jul 9, 2025 at 7:14 AM
    #525
    verruckt
    verruckt Member
    You are correct. I contacted them and Yurii replied right away with the advice to turn off dip switch # 3 and that did it. By default switches 123 are set to on. No firmware update in my case.
    Thank you for your time and advice.
  6. Jul 9, 2025 at 6:01 PM
    #526
    eaglehawaii
    eaglehawaii Well-Known Member
    Hawaii
    22 Super White.. ... 18 Magnetic Gray ... 02 Gold RIP in 25
    I'm going to save this in my Taco file folder. Perhaps next time, I'll take a pix of the dip switches to have a record of the settings that work in case one of them get accidentally changed. Won't be a bad idea to do for any electronics that have exposed dip switches.
  7. Jul 9, 2025 at 8:47 PM
    #527
    verruckt
    verruckt Member
    https://imgur.com/a/TB6Vwuy
    here
    eaglehawaii[QUOTED] likes this.
