Carbon fiber hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OriginalMan, May 17, 2019.
  1. Jan 22, 2023 at 5:41 PM
    #381
    Levelz
    Levelz Well-Known Member
    2021 Taco TRD Sport
    Def not aluminum. Stamped steel.
  2. Jan 22, 2023 at 5:49 PM
    #382
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    I've only had mine for a couple of months but it's doing fine. I drive on a highway everyday so I check the part that latches anytime I get under the hood and it's always solid as a rock. The hood seems to do fine at high speeds. I don't even consider latches anymore, I was on the fence before I installed it. I was told its more of a "cover your ass" for Seibon in case some freak accident were to happen.
    glove916[QUOTED] likes this.
  3. Jan 22, 2023 at 7:57 PM
    #383
    erok81
    erok81 Well-Known Member
    Imposter
    I’ve run carbon hoods/trunks on a few vehicles. Granted they were garage kept but did sit outside while at work, etc. as long as you have a quality brand it’s going to look fine.
    With how many hoods I’ve seen fail I’d use hood pins. You can get really cool looking flush mount ones. Don’t have to use 90’s chrome pins anymore. :)
    vivid02 and glove916[QUOTED] like this.
  4. Jan 22, 2023 at 10:08 PM
    #384
    glove916
    glove916 New Member
    Grant
    Any tips on how to remove the 2 spray nozzles from the OEM hood?
  5. Jan 22, 2023 at 10:42 PM
    #385
    jamie_aug
    jamie_aug Active Member
    James
    2021 Toyota Tacoma
    Accutune Offroad 05+ Tacoma Mid Travel Suspension Kit, Stage 5A – Fox SKU: AOR-3000-0021 Adventure tune -Front Coilovers: Fox 2.5 Performance Elite Series, DSC -Sway bar relocation brackets included with shocks -Front UCA: AccuTune Offroad -Rear Shocks: Fox 2.5 x 12″ DSC – Modified -Rear Archive Garage Shock Relocation Brackets -Rear Springs: Icon RXT Pack -Archive Garage Rear Shock Relocation Brackets -Archive Garage Hammer Hangers -Rear U-Bolt: AccuTune Offroad -Rear +4″ Crown Performance Brake Lines Remove: Front UCA - Icon Delta Joint Add: Camburg Kinetik Series Billet Upper Control Arm, Uniball, 05+ Tacoma, 03+ 4Runner SKU: CAM-310103 Add: CAMBURG TOYOTA TACOMA PRE/4WD 05-20 PERFORMANCE SPINDLE KIT SKU: CAM-310114 Add: CAMBURG TOYOTA TACOMA PRE/4WD 16-20 PERFORMANCE LOWER ARM KIT Code: CAM-310126 Add: '05-CURRENT TOYOTA TACOMA CAMBURG FRONT BYPASS SHOCK MOUNT KIT add recommended FOX 2.5 bypass shock PART#: CAM-310052 Durpbumps - 3rd Gen Tacoma Front Off Road Bump Stops (2016-2023) DBF212 DRT Fab TACOMA CAB MOUNT RELOCATION DRT Fab UNIVERSAL HITCH SKID PLATE Fuel Offroad - Block Model D752 - 17x9 Matte Anthracite w/ Black Ring Negative -12 offset Nitto Ridge Grappler 285/70r17 Nitro Gear and Axle '16-CURRENT TOYOTA TACOMA W/8.75 INCH REAR 4.88 RATIO FRONT AND REAR GEAR PACKAGE KIT VENDOR: Nitro Gear and Axle PART#: GPTACO2016-4.88-8.75 Yes to REM gear polish OV Tune Tacoma 3.5L vF Tune Pack Get right tune for gearing of 4.88 Vftuner.com Nitro Gear and Axle '05-CURRENT TOYOTA TACOMA 8" CLAMSHELL STUB AXLE BUSHING VENDOR: Nitro Gear and Axle PART#: NITRO-AKT8S S.O.S Performance Stoptech 6 PISTON FRONT BIG BRAKE KIT fits 2005-21 TOYOTA TACOMA TR340.6TA SOS PERFORMANCE 4x4 Black Slotted rotors Paint fender flares cement gray to match Custom Viper Cut Front bumper. Seibon Carbon - TR-STYLE CARBON FIBER HOOD FOR 2016-2021 TOYOTA TACOMA, custom painting to look like a TRD Pro. C4 Fab - TACOMA ROCK SLIDERS / 3RD GEN / 2016+, shipped raw, line-x by local shop TACOMA BED STIFFENERS - 3RD GEN, 2016-2023 TOYOTA TACOMA ACCESSORIES,REAR CHANNEL BED STIFFENERS, PART #48676 Wet Okole Seat Covers WeatherTech Floor Liners Full Custom Stereo with 2x8” subs behind the seat, Kenwood head unit. Taco Garage - Dashtop Multi Mount (DMM) for RAM mount system Toyota - TRD Pro Skid Plate Toyota – Bed Mount Step
    Here is mine, painted to look like a TRD Pro… no hood pins, latch is rock solid. Been really happy with it.
  6. Jan 23, 2023 at 8:43 AM
    #386
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    On the stock hood, the latch hoop is welded to the hood structure. On a composite hood, the latch hoop is wrapped with fiberglass plies and bonded with epoxy. That's a potentially unreliable attachment method and can fail without warning. That's why they stipulate hood pins as a backup.
  7. Jan 23, 2023 at 8:48 AM
    #387
    mushroom_man7
    mushroom_man7 Well-Known Member
    that looks really nice
    Malvolio and jamie_aug[QUOTED] like this.
  8. Jan 23, 2023 at 9:17 AM
    #388
    OhNoItsMe
    NM
    2022 TRD OR
    Yea I don’t care
    BigJanko likes this.
  9. Jan 23, 2023 at 9:33 AM
    #389
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^I have A-pillar grab handle and a devil horn emblem on the steering wheel airbag cover. Live and let die :thumbsup:
    Bertw192 likes this.
  10. Jan 23, 2023 at 9:47 AM
    #390
    OhNoItsMe
    NM
    2022 TRD OR
    Like a claymore lol.. If it ever happens I will definitely be pissed and I’ll come back to let you know I should’ve listened lmao :oops:
    3JOH22A[QUOTED] likes this.
  11. Jan 24, 2023 at 6:31 AM
    #391
    Levelz
    2021 Taco TRD Sport
    That looks really good. Gives a nice contrast against the grey.
    Malvolio likes this.
  12. May 30, 2023 at 6:40 PM
    #392
    Taco Pastor
    Taco Pastor Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
  13. Aug 24, 2023 at 6:11 PM
    #393
    OhNoItsMe
    NM
    2022 TRD OR
    Figured I’d post this to help ease some people’s minds on the hood without pins.
    I got into a wreck a few weeks ago when some lady blew through a red light.. The Seibon CF hood took on some damage from the hit and the latch that’s built into the hood got bent a little sideways but it’s still solid as a rock in there. I was shocked that it bent it but it still doesn’t wiggle or anything at all. IMG_9737.jpgIMG_0017.jpg
    3JOH22A likes this.
  14. Aug 24, 2023 at 6:47 PM
    #394
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    GOD DAMN PHEW:eek:
    igiman[QUOTED] and OhNoItsMe like this.
  15. Aug 24, 2023 at 7:09 PM
    #395
    jamie_aug
    James
    2021 Toyota Tacoma
    Wow glad you're okay. No doubt the front bumper helped.
    Good to know. Still not running pins on mine. Still rock solid.
  16. Aug 24, 2023 at 9:03 PM
    #396
    OhNoItsMe
    NM
    2022 TRD OR
    Thanks! I actually bought pins just for peace of mind.. I just never got around to installing. Kind of glad that I didn’t though since I’d be replacing them now if I had :laugh:
    Her Chevy was declared a total loss
  17. Jan 5, 2024 at 3:20 AM
    #397
    Wero94
    Wero94 Well-Known Member
    2016 tacoma trd Sport double cab
    It the vent a functioning one?
  18. Jan 5, 2024 at 3:25 AM
    #398
    Wero94
    How much?
  19. Jan 5, 2024 at 8:29 AM
    #399
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I bet the Ishikawa people aren't laughing about this now
  20. Jan 5, 2024 at 10:41 AM
    #400
    spicy_fish_taco
    responding to a 3 year old post...
