Cargo Light Switch installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JasonJason, Feb 8, 2021.
  1. Jul 15, 2022 at 4:58 PM
    #41
    caribe makaira
    Caribbean, Puerto Rico
    :hattip:
    Yes
    For the added lights, chassis ground. There's a hole next to the factory ground (between rear light assembly area and rear tire-driver's side)
    :confused:
  2. Jul 29, 2022 at 4:52 PM
    #42
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    thanks mr. caribe.
    just bought a canopy and was looking at brake light splice.
    thinking i will wire anytime 12v plug and canopy dome- bed light circuit somehow
  3. Jul 29, 2022 at 4:54 PM
    #43
    caribe makaira
    PM @daveeasa, he has a solution so you don't go cutting anything.
  4. Jul 29, 2022 at 4:58 PM
    #44
    bush rat
    BC
    2022 6MT Access Cab
    similar to the canopy manufacturer type harness that goes between the brake light bulb?
  5. Jul 29, 2022 at 5:07 PM
    #45
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    We are talking about this?
  6. Jul 29, 2022 at 6:49 PM
    #46
    bush rat
    BC
    2022 6MT Access Cab
    thanks Dave.
    i may consider this option
  7. Aug 20, 2022 at 6:50 PM
    #47
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    Wishing my truck was one year younger at this point. So to be clear. I need to run a separate wire if I want cargo lamps w/ my 3 rd brake light. There is no preexisting wire harness from behind the dash near my left knee??
    2019?sr 5. V6.
  8. Aug 20, 2022 at 6:55 PM
    #48
    caribe makaira
    Remove any of the rear lamp assemblies (x2 bolts and pull) and check for the plug...
    Rocket23[QUOTED] likes this.
  9. Aug 20, 2022 at 6:57 PM
    #49
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    What do you think my chances are lol
  10. Aug 20, 2022 at 6:59 PM
    #50
    caribe makaira
    50:50:spending:
  11. Aug 20, 2022 at 7:02 PM
    #51
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Yeah. I’m feeling that. Lol. :fingerscrossed: Thanks for the lightning quick reply! :thumbsup:
  12. Aug 20, 2022 at 7:03 PM
    #52
    caribe makaira
    Just 2 bolts and a tug (and illumination to view) 5min tops...
  13. Aug 20, 2022 at 7:05 PM
    #53
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I’ll replace the 3rd brake light. Anyways and figure a wiring solution later if it isn’t there.
  14. Aug 20, 2022 at 7:10 PM
    #54
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Thanks again. Tapping out. Been a long day.
  15. Aug 20, 2022 at 7:10 PM
    #55
    caribe makaira
    I'm referring to the rear light assemblies...
  16. Aug 20, 2022 at 7:11 PM
    #56
    caribe makaira
    :thumbsup:
  17. Aug 24, 2022 at 3:55 AM
    #57
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    So that harness can be used for bed lighting?
    What about a wired harness not being used for my cargo light under the headliner??
  18. Sep 21, 2022 at 11:40 AM
    #58
    Slynky
    Slynky New Member
    Chuck
    I guess this is about all I can find on cargo light/switch install. The taillight portion looks easy enough but the dash part is a bit daunting for me--somewhat of a nerd. :confused: :notsure:
    So, I ordered and have both parts that I need, I think. The black rocker switch for the dash and the blue relay switch/plug thingy. I had hoped it would be as simple as getting into the dash area and connecting these components. Heck, I can't find any instructions on removing the small panel on the dash--the panel that also houses the "blank" for the cargo light switch. I have the install instructions from Toyota but they only show illustrations for the taillight portion of the process. Then they refer you to their repair manual for the switch install. I downloaded the manual and searched and found the cargo switch stuff--not much help at all.
    Is there a video or set of illustrations on how to remove that small panel on the lower left of the dash? :help:
  19. Sep 21, 2022 at 11:57 AM
    #59
    daveeasa
    David
    PNW
    Reach behind and push. MESO has an install video. I think he used a knife, but he has mad skills. I like the reach around maneuver.
  20. Sep 21, 2022 at 11:58 AM
    #60
    caribe makaira
    Using a dash removal tool (plastic spatula type) place to top edge of the cubby and pop open all corners.
    Slynky[QUOTED] likes this.
