Cargo Light Switch installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JasonJason, Feb 8, 2021.
  1. Oct 4, 2022 at 2:37 PM
    #101
    caribe makaira
    Caribbean, Puerto Rico
    Like I posted before, remove the switch and test the switch terminals. It is a $3.00 switch.
  2. Oct 4, 2022 at 2:39 PM
    #102
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    It may be circuit dependent, yeah? Sounds like this circuit floats at 12v? Or enough to fire the indicator led.
  3. Oct 4, 2022 at 2:58 PM
    #103
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    Ok so indicator light lights up when it is connected to 12v, did it straight from my battery it will also light up if I connect it to the blue wire on the harness
  4. Oct 4, 2022 at 2:58 PM
    #104
    caribe makaira
    It's not a "ground", it needs to make ground in order to activate the Cargo Lamp relay.
    Did you do ON & OFF on the switch?
  5. Oct 4, 2022 at 3:06 PM
    #105
    Brex69
    Yes, indicator light stays on in both positions
  6. Oct 4, 2022 at 3:14 PM
    #106
    caribe makaira
    Switch wire inputs on the switching side not the switch illumination, that is "blue" or battery 12v to red and green to ground.
  7. Oct 4, 2022 at 4:00 PM
    #107
    Brex69
    Ok, tried it and the switch stays illuminated. I had to get it back together so I’ll have to live without indicator light.
    Thanks for your help I really appreciate it.
    Oh and the switch cost 20.00, where you buying 3.00 switches? Lol
  8. Oct 4, 2022 at 4:03 PM
    #108
    caribe makaira
    Same place the company you bought it from buys "theirs"...China.
    I hope you're not confusing the circuit ON indicator LED with the switch illumination LED...have a good one.
  9. Oct 4, 2022 at 4:08 PM
    #109
    daveeasa
    David
    PNW
    I would just wire it up as a power switch feeding a relay to do the ground switching.
    Connect the wire you want to be ground switched to pin 30 of the relay.
    Connect pins 85 and 87 of the relay to ground.
    If your relay has an 87a, leave it floating (cap it or ignore it).
    Connect fused power (add a fuse) to the custom switch input wire
    Connect the custom switch output wire to 86 on the relay
    Now the indicator light will work, switch illumination will work, and the circuit will establish ground with pushbutton switch as you desire.
  10. Oct 4, 2022 at 4:14 PM
    #110
    caribe makaira
    OP, is just substituting the OEM Cargo Switch with a China Switch (without door select). Circuit already has a hot fused source to a relay. A simple ON/OFF switch is all that's needed. But...
  11. Oct 4, 2022 at 4:33 PM
    #111
    Brex69
    So what switch do you suggest? The one I have is an on/off switch. Link to non China switches?
  12. Oct 4, 2022 at 6:45 PM
    #112
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    And here I sit waiting for a chance to visit a pick ‘n’pull.
    I just need the trd panel, cargo switch (oem). And the correct third brake light that supports cargo lighting.
    Anyone have any of these parts listed??
  13. Jan 28, 2023 at 9:34 AM
    #113
    hahnster
    hahnster Well-Known Member
    2022 Tacoma 4x4 V6 AT
    3" Lift, TRD Pro Grill, TRD Skid Plate, 285x70/r17 BFG KO2's, LED Headlights, Rock Sliders
    I have a 2022 SR access cab. It does not have the cargo light where the 3rd brake light is. I have read all the posts and If I understand it correctly In order to add a cargo light and the 2 bed lights I would need
    - on off switch to replace the bank in the dash panel
    - new 3rd brake light with cargo light
    -bed light kit
    does that sound about right? Anyone have the part numbers for the dash switch or 3rd brake light with cargo light?
    thanks a lot!
    Rocket23 likes this.
  14. Jan 28, 2023 at 10:29 AM
    #114
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Virtually impossible to find a replacement cargo/3rd brake light lamp. that will fit my 2019. I doubt the 22’s are any different I gave up on it. I do have an oem switch if you want to pm me.
  15. Jan 28, 2023 at 10:39 AM
    #115
    caribe makaira
  16. Jan 28, 2023 at 10:41 AM
    #116
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
  17. Jan 28, 2023 at 10:45 AM
    #117
    hahnster
    Does anyone know if I install the switch and the bed lighting kit will the bed lights work even though I don't have the cargo light up with the 3rd brake light?
  18. Jan 28, 2023 at 11:14 AM
    #118
    caribe makaira
    If you have verified your Taco has the harness inside the rear headlight assemblies, I'd say yes.
  19. Jan 28, 2023 at 3:25 PM
    #119
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    pick-n-pull has 3rd gen's by you?!? they stop at early 2000-anything around me.
    Rocket23[QUOTED] likes this.
  20. Jan 28, 2023 at 3:43 PM
    #120
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I managed a light but my access cab is a different animal than the other 3rd gens. So there it sits on a shelf.
