Cargo net
Discussion in '2nd Gen. Tacomas (2005-2015)' started by charliewhiskey, Mar 10, 2015.
  1. Mar 10, 2015 at 10:38 PM
    charliewhiskey
    charliewhiskey [OP] Active Member
    Brevard county FL
    I am looking for a cargo net to hold things from sliding around the bed. What do you recommend?
  2. Mar 10, 2015 at 10:43 PM
    NosiBaLasi
    NosiBaLasi RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    I also recommend a cargo net
    kellzbellz563 likes this.
  3. Mar 11, 2015 at 2:26 AM
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    Harbor Freight has a light-duty net for under $10. Used it a few times to keep stuff in place but it is light-duty.
  4. Mar 11, 2015 at 3:45 AM
    Va Bowhunter
    Va Bowhunter Well-Known Member
    Shawn
    VA
    05 Tacoma TRD
    ABS winch bumper, 8,500 smitty built winch
    thanks for the info. i'm looking for something as well.
  5. Mar 11, 2015 at 4:43 AM
    Oday450
    Oday450 Active Member
    Peoples Republic of Maryland
    '07 Speedway Blue Off Road AC; '14 Silver Sky Sport AC
    Amazon has the Toyota net for @ $29.00. It hooks to the bed cleats and can be set wherever convenient.
  6. Mar 11, 2015 at 5:29 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    A cargo net or plenty of straps as well as a bed mat.
  7. Mar 11, 2015 at 5:33 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I built my own. Good for little stuff like groceries and cases of beer. :cool:
  8. Mar 11, 2015 at 6:03 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  9. Mar 11, 2015 at 6:05 AM
    MrShoehorn
    MrShoehorn Well-Known Member
    Justin
    North Augusta, SC
    12 DCSB TRD Sport Blue Ribbon
  10. Mar 11, 2015 at 7:02 PM
    charliewhiskey
    Brevard county FL
  11. Mar 11, 2015 at 7:09 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
  12. Mar 11, 2015 at 7:55 PM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    what type of boxes are those in the front? How did you mount the ammo cans to the rail? Thanks for the info.
  13. Mar 12, 2015 at 2:40 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    One box is just a plastic storage bin I got for free from a member here. The other is just a cooler I painted black. The ammo cans are held on with carriage bolts.
  14. Mar 12, 2015 at 4:05 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Luse: that is by far the cheapest rail mount solution I've seen. Good stuff.
    I have a cheap net by Reese ($10.)from Walmart set up exactly like Luse. It works well for groceries and of course, beer. Secured to stock rail mounts with Carbiners on top and a bungee across the bottom. Cheap easy and fast to remove.
  15. Mar 18, 2015 at 8:43 PM
    charliewhiskey
    Brevard county FL
    I got the toyota cargo net. Love it. And it's cheap.perfect choice.
  16. Mar 18, 2015 at 8:59 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Boo to the weak ass net. KB VOODOO cargo management system. Let's see you try to contain a couple of propane tanks with your net.
  17. Mar 19, 2015 at 8:42 AM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    True dat Ryan. I have 2 propane tanks, both in milk crates. cargo net holds em fine.
  18. Mar 19, 2015 at 8:48 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Looks nice and I'm sure it works great, but it's not really a net. I like having mine because it will contain most of what I want to put back there. When I need some more space just take the net down and lay it to the side and I have my bed back.
  19. Mar 19, 2015 at 11:41 AM
    drscott11
    drscott11 Well-Known Member
    ^^This^^ is what I went with and could not be happier. Then get a pair of these to store them and the factory cleats.
    Mobtown Offroad Locking Bed Doors (I accept commissions...lol.)
    http://mobtownoffroad.com/product/storage-door/
