Carier bearing drop with stock suspension and rear TSB
Discussion in 'Suspension' started by Nixinus, Feb 13, 2013.
  1. Feb 13, 2013 at 8:42 AM
    Nixinus
    Nixinus [OP] Well-Known Member
    Oregon
    2010 4x4
    Been trying to find info on this. I have a stock 2010 4x4 AC and I notice a vibration under acceleration at times. It's mild but its there. Was wondering if a small CB drop would be a problem on a stock suspension? What I'm worried about is the drive shaft not having enough play with the CB drop when the suspension is under full load, like hitting a big dip. My thinking is that by decreasing the angle of the shafts, I will shorten the distance the shafts can travel (compress) when the suspension is compressed. I'm looking at this in regards to the distance between the ends of two segments when the angle in between them is decreased. Anyone do this on a stock suspension?
    Thanks for reading through my painful description and explanation.
  2. Feb 13, 2013 at 8:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Try flipping the CB and see if that helps. I flipped mine 180 degrees, bolted it back in place and filled around the bearing itself with RTV Silicone to help limit the amount of play it had with the stock rubber. It seems to have helped.
