Carista App
Discussion in '3rd Gen. Tacomas (2016-2023)' started by timkins42, Oct 15, 2017.
  1. Feb 7, 2018 at 2:08 AM
    #41
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Nah, if I go to “DRL OFF” on the stalk, DRLs go off.
    The setting allows the DRLs to be on when the stalk is in auto and it’s bright outside.
    This is customizable through the radio I believe.
  2. Feb 20, 2018 at 9:28 AM
    #42
    HellinaHelmet
    HellinaHelmet Well-Known Member
    Nick
    N GA
    2017 SSM DCLB TRD OR 4x4
    Does this only disable the chime when you are moving or when you start the vehicle?
  3. Feb 20, 2018 at 9:39 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you are talking about the seat belt chime, it is off permanently. Only the red instrument light remains.
  4. Feb 20, 2018 at 9:41 AM
    #44
    HellinaHelmet
    Nick
    N GA
    Thanks, can you provide some insight. Mine is still beeping 5 times when I start. IMG_1518.jpg
  5. Feb 20, 2018 at 9:44 AM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is how I have mine set. I can back out of the garage, pull in, and drive with no chime. Just yesterday while heading down a long straight, I unlatched my belt to take off a sweatshirt without a sound.
    I did you get 'are-you-sure' confirmation prompts when you changed the setting?
  6. Feb 20, 2018 at 9:49 AM
    #46
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Do you guys know if you can get the horn to honk when you lock the doors from the key fob? My old Subaru did this and it’s great peace of mind when I’m halfway across a parking lot and I can hear the vehicle beep to know it’s locked.
  7. Feb 20, 2018 at 9:51 AM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I know that it can be changed in the app. I used it to shut off everything but the outside light flashes. I think from within the Entune setting, you can change it between the horn and the quieter chime?
  8. Feb 20, 2018 at 10:02 AM
    #48
    HellinaHelmet
    Nick
    N GA
    Yeah I had to acknowledge an "are you sure" prompt as well. What kind of OBD reader are you using?
  9. Feb 20, 2018 at 10:07 AM
    #49
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Ok then I’ll give this a shot. That horn beep would be huge for me haha
    It can’t be done through Entune. I’ve been through all the screens a few times
    tonered[QUOTED] likes this.
  10. Feb 20, 2018 at 10:11 AM
    #50
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    An ELM 327 BT adapter that I bought in 2014. It is not one from Carista.
  11. Feb 20, 2018 at 10:12 AM
    #51
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what is great about these customizations. You can make it your own.
    doublethebass[QUOTED] likes this.
  12. Mar 8, 2018 at 6:21 AM
    #52
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    I fired up Carista the other day and about the ONLY thing I found I could change in it that I can't from Entune is the number of lane change flashes! I have Techstream but I haven't been able to get it to communicate with my truck. I have the adapter cable I got, lights flash on it when connected, and Techstream is running on Win 10 but no communications! Will Techstream work with a wi-fi OBDII unit? I haven't tried yet.
  13. Mar 8, 2018 at 6:27 AM
    #53
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Apple locks down their Bluetooth stack. Manufacturers have to pay Apple to use their Bluetooth, and therefor MANY Bluetooth devices will not work with Apple because they don't want to pay the ransom. However, wi-fi OBDII adapters will work with any iPhone app I have tried it with including Carista.
  14. Apr 27, 2018 at 1:07 AM
    #54
    GoGriz406
    GoGriz406 Well-Known Member
    David
    Jacksonville, NC ....for now
    2017 DCSB MGM TRD Off-Road
    Does anyone know if there is an option (Carista, Techstream, etc.) for when you park and turn off the truck, the stereo will remain on until you open the drivers door? This would be great!
    RedWings44 likes this.
  15. Sep 20, 2018 at 10:37 AM
    #55
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hey, Folks.
    I just got an app update for Carista on Android. The 3rd Gen Taco is now listed. Also, it says that we can now service the TPMS (add new sensor IDs).
    MrBrooks likes this.
  16. Oct 2, 2018 at 8:44 AM
    #56
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Can Carista allow windows to be rolled up with the fob like my old VW? That would be enough to get me on-board.
  17. Oct 2, 2018 at 9:07 AM
    #57
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe that you can change some of the auto up / down settings. If there is not a window button on the remote, then I do not think there is an option to enable that. Basically, it allows you to change the customizations that are listed in the owners manual which only a dealer can typically do.
    I had hoped to find a function in Carista or TechStream that would turn off the key in chime. No luck in either.
    Still, there are a bunch of helpful changes that can be made. If you already have a working BT adapter, then there are free subscription options, just remember to cancel early! If you buy the Carista adapter for about $20, you get a free month I believe.
    The Carista adapter should work with Torque and OBD Fusion afterward. You should confirm that though.
    oconnor[QUOTED] and MOC221_ like this.
  18. Oct 2, 2018 at 9:11 AM
    #58
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Unless something has changed, I can confirm that the Carista adapter works with OBD Fusion (for IOS). The in-app purchase of Toyota specific PIDs (10 bucks) is worth it too IMHO.
  19. Oct 2, 2018 at 9:14 AM
    #59
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sweet! Thanks for confirming.
    Also, I have a subscription to Carista that will expire on October 19th if any local folks want some changes. Yeah, I didn't cancel the free week early. Haha!
  20. Oct 2, 2018 at 9:15 AM
    #60
    oconnor
    oconnor Where am I?
    Midwest
    Bummer. My GTI just used the lock/unlock keys held down to raise/lower windows. Worked great when you are in the house and it starts to rain.
