Carpet removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaBanjo, Oct 4, 2017.
  1. Oct 4, 2017 at 7:03 PM
    ToyotaBanjo
    ToyotaBanjo [OP] Well-Known Member
    Outer banks
    2006 DC 4x4 Sport
    None
    i have a 2004 crew cab that I just got...it is beyond nasty inside....the carpet is at the point where I don't think it can be cleaned properly inside the truck...so I am thinking I would be better off to remove the seats and just take it out and clean...it would seem that this would just be a matter of removing the seats and then the carpet, pressure washing and cleaning it and reinstalling?
    Are there any unknown hang ups or obstacles or hints or pointers?
  2. Oct 4, 2017 at 7:24 PM
    Glamisman
    Glamisman Well-Known Member
    you can get replacement premolded carpet for under $200.
    The pointers that I can give is go slowly if you put in new carpet... you will have to trim it and the trim points around the center console and where the seats / seat belts bolt in become a hassle, there is much room for a trimming error. You might want to think about some additionl padding while you are at it... it quiets the cab and insualtes it at the same time.
  3. Oct 4, 2017 at 7:28 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
  4. Oct 4, 2017 at 7:41 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Just did mine a couple of weeks ago. A good pressure wash will really clean it up. In addition to the seats, you will need to remove the sill plates, seat belts(bolted to the floor), center console, kick panels, center post panels, etc. I would recommend that you also removed the panel behind the rear seat, and add Frost King to all the panels and floor. It really cuts down on road noise/tire noise. I did my doors and roof panel as well. Cost was about $100 in materials.
    robertjohnsonjr likes this.
  5. Oct 4, 2017 at 8:09 PM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Seagull...what is frost king? Is that a spray? Also what do you mean roof panel? Thanks for the help!
  6. Oct 4, 2017 at 9:24 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    It is a foil/foam duct insulation, available at Home Depot: http://www.homedepot.com/p/E-O-12-in-x-15-ft-Self-Stick-Foam-Foil-Duct-Insulation-FV516/100028603, You cut it with a utility knife. You should also have a small roller, https://www.amazon.com/gp/product/B00GMOI98S/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1. For the inside of the door, the cavity where the glass goes down into, I used this. http://www.homedepot.com/p/USEAL-USA-4-in-x-66-7-ft-NonSkid-Roof-Tape-USEAL-8872NF4/204194240 This is tar based, with foil, rather than foam. Smells bad, so I would only use in that cavity, which is not open to the interior. I thought that since it was petroleum based, it would be better in a somewhat damp environment, and not promote any rust. For the part right under the plastic door panel, I did use the Frost King.
    Since I had almost all of the interior out anyway, I went ahead and pulled down the headliner, and applied the frost king to the roof panel.
    Colchicine, Beee1985 and chrslefty like this.
  7. Oct 4, 2017 at 9:52 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    My house just flooded and some of the water got on my vinyl floor kit. So I'm thinking insurance will give me money to purchase a new one. I can sell my other one for cheap if your interested. It's vinyl so it should be good to go. The water shouldnt have affected it at all.
    kgarrett11 and Dalandser like this.
  8. Oct 5, 2017 at 1:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm going to dye mine black like I did in my 2nd gen. Having light colored carpet in a truck is like having light colored carpet in a daycare...
  9. Oct 5, 2017 at 2:04 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    How did the carpet dye work out for you? I'm thinking about it in my 2nd gen. Any tips or advice you could give on the process? Does the dye have an odor like spray paint? Was the dye coverage even? Thanks!
  10. Oct 5, 2017 at 5:37 AM
    Chadley22
    Chadley22 Well-Known Member
    Chad
    Tacoma
    That's an awesome idea, adding the Frost King. I'd love to do mine someday.
    Is there any availability of replacement (pre-cut) carpet for the first gens?
