Carpet under passenger side wet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boilerman, Jan 15, 2011.
  1. Jan 15, 2011 at 8:20 PM
    Boilerman
    Boilerman [OP] Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Went to go get the mail today and noticed a musty smell in the truck. Lifted up my passenger side floor mat and it was wet or slightly damp. I have the factory floor mats as well as rubber aftermarket mats on top of the factory mats. Could I just be getting condensation from having too many mats, or should I just remove the carpet factory mats and keep the rubber mats. I can't find any leaks from rain under the passenger side at all.
  2. Jan 15, 2011 at 9:03 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    well here is what just happened to me. i spilled a coffee on pass. side. i used a carpet cleaner, then a prof. cleaning. coffee smell was gone but then the must smell came through. i ended up having mold in the padding under the carpet. i had to replace the entire interior carpet. if its under your carpet and getting moldy, you kinda sol. i tried everything
  3. Jan 15, 2011 at 9:03 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    well, My mercedes experience would say clogged A/C drain, rain storm back fills heater/a/c box and you get wet floor; or Just A/C condensation and clogged drain. But check the wheel well area for any missing plugs.. I have no tacoma specific experience to lend.
  4. Jan 15, 2011 at 9:12 PM
    blackonwhite
    blackonwhite Well-Known Member
    06 white tacoma black 17' ssr wheels
    happened to me a couple times in my truck. Passenger side kept being soaked after rain. finally one night while it was pouring i went and laid in the dang thing and looked around. If u pull the kick panel out there is a rubber ball looking thing that pops into the sheet metal up and behind the kickpanel area. Seems like half of it sticks through one side and half through the other. Mine had some how got knocked out and water was pouring in around it. All i had to do was pull it back through till it locked in to place. Try looking for that if you havent already located the problem
    bryanbyers28 likes this.
  5. Jan 15, 2011 at 9:13 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
