carrier bearing/ center support bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smitty8076, Nov 24, 2014.
  1. Nov 24, 2014 at 2:04 PM
    smitty8076
    smitty8076 [OP] Well-Known Member
    What are the symptoms or indicator u have a bad one? Like what kind of noise does it make?
  2. Nov 24, 2014 at 3:18 PM
    RedHarris
    RedHarris Member
    So California
    06 Tacoma TRD
    Loud Rumbling noise,,,,sorta like a bad U-Joint but MUCH louder.
    Drive on the freeway, (loud rumble right?) now open the rear slider window and the rumble gets REALLY loud. Thats what it was like when my rear carrier bearing started to go.
    If it IS the carrier bearing, you'll want to replace it ASAP. If that bearing shrapnels in your rear Diff, it will probably destroy everything in the Pumpkin.
    My rear carrier bearing started going bad @ 150,000 miles.
    The bearing itself is a Tapered Roller bearing. Its a special Toyota Part, not some standard Generic Bearing.
    The Repair was beyond my ability to fix (daily Driver) and cost be $900 to repair at a local Mechanic (not the Dealership). The Bearing kit alone was more than half the cost of the repair.
  3. Nov 24, 2014 at 4:28 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    The carrier bearing/center support bearing is the bearing on the 2 piece driveshaft. It is not in the diff. You are thinking of the pinion bearing.
  4. Nov 24, 2014 at 7:52 PM
    RedHarris
    RedHarris Member
    So California
    06 Tacoma TRD
    Yes, you are right, MY problem was the Pinion Bearing.
    Mind Fart on my part,,,,,mixing up the two.....
    Sorry OP......Ignore my previous post.:facepalm:
  5. Nov 25, 2014 at 2:14 PM
    smitty8076
