Carrier Bearing Drop Kit
Discussion in 'Suspension' started by NCTacoma09, May 23, 2010.
  1. May 23, 2010 at 9:59 AM
    NCTacoma09
    NCTacoma09 [OP] Stand for Nothing or Die for Something
    Andrew
    North Carolina
    Black 09 Double Cab 4x4 V6
    Just read on the Lift FAQ guide, the author thinks a carrier bearing drop kit is a not a good idea. Can anyone explain this too me. I was planning on getting one when I order my lift.
  2. May 23, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I personally think the CB drop kit drops it too much. Ideally, it should only be dropped 1/2" to 2/3". I suggest useing larg washers to space it, and get the desired drop, only if you have vibes after the lift.
    AR15xAR10 likes this.
  3. May 23, 2010 at 10:02 AM
    NCTacoma09
    Andrew
    North Carolina
    So I should install my lift and wait to see if it vibrates?
  4. May 23, 2010 at 10:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  5. May 23, 2010 at 10:03 AM
    NCTacoma09
    Andrew
    North Carolina
    Ok thanks
    cjizzle801 likes this.
  6. May 23, 2010 at 10:04 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  7. May 23, 2010 at 10:08 AM
    NCTacoma09
    Andrew
    North Carolina
    Tacomaman06, read your write up very helpful thanks.
  8. May 23, 2010 at 10:08 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    hey chris the CB drops from toyteclifts arent they only 3/8 inch? i callled them and asked
  9. May 23, 2010 at 10:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure. I was told they are 1"
  10. May 23, 2010 at 10:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    they use two small 3/8inch pieces of steel.
  11. May 23, 2010 at 10:20 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    Sparks, NV
    2011 TX TRD 4x4 DC
    OME Lift W/886 Coils/LR UCA's/BAMF LCA Skids/Daker Leaf Packs Fab Fours front bumper/Warn M8000 winch Relentless Fab Rear Bumper/Tailgate Skin/Front skid plate DB Fab Grille Insert with Baja Designs Cube LED's 285/75/16 Nitto Terra Grapplers N-Fab Steps Compustar remote start UWS low pro box Carhartt Seat Covers/Door Inserts/Console Cover OEM Bed Mat Bulletproof Fab Engine Tray/Lower Grille Insert .50 Cal Antenna/Valve Stem Covers Custom Fab Console Lock Box Custom Shift Knob Dash Mat Window Tint Rugged Ridge Floor Mats Blacked Out Emblems Color Matched Grill Surround G-Tek Door Sill Protectors Wheelskins Steering Wheel Cover EGR In Channel Vent Visors FJ emblem on the tailgate Northstar battery TRD battery tie down Illuminated 4X4 switch Bed stiffeners/Bed Extender with custom mounts Redline hood struts Relocated rear diff breather Console Molle Boards Lot's of patches!
    Yeah the toytec drop kit is 3/8, I used one on mine but like Chris and Will have said just get some washers or drill out a piece of flat stock and it will work the same. Overall I bought it because with all the $'s I spend whats another few bucks to have everything you need when doing the install but now that I know I would just make my own.
  12. May 23, 2010 at 10:24 AM
    johnw
    john
    orlando florida
    oh they told me just 3/8 inch thick and thats how thick i made each CB side for my truck vibes a small amount at take off but that it
  13. May 23, 2010 at 10:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. I would go by what everyone else said, and call them 3/8". I wasnt sure.
  14. May 17, 2013 at 11:03 AM
    Me Taco Too Much
    Me Taco Too Much Good Job!
    Dennis
    Apache Junction, Arizona
    06 PreRunner
    Bringing this up...
    Just no lectures please...
    Replaced my carrier bearing about 2 months ago after it went bad.
    '06, prerunner, buy the way.
    springs and block in the rear, no lectures please.
    Any hoo, was getting weird squeaking from somewhere.
    Took it to stealership, they said I need to get my drive line lengthened?
    They said is was the current angle on the drive line?
    If so, will a carrier bearing drop of say, 1 in help?
    Crazy screeching when I decelerate. Other then that, no vibes no noise.
    Thanks everyone for you help.
    D
  15. Jun 24, 2017 at 7:09 PM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    a cool sticker and a baseball card With clothes pin, sounds awesome ! wicked
  16. Aug 10, 2017 at 10:45 AM
    08comatose
    08comatose Skatersmate First Class
    Michael
    Chincoteague, VA
    2008 TRD OR Indy Ink
    Is that monotone screeching, pulsated screeching, or decreasing screeching?
    For the OP, wait until you lift and feel takeoff vibes. Try washers first to see if it helps (because washers are cheap), then purchase a kit. Call the manufacturers first to verify the amount of drop.
  17. Aug 10, 2017 at 11:49 AM
    08comatose
    Michael
    Chincoteague, VA
    I just called. They said at first it was 3/4 total, then when I pressed they admitted 1".
