Carrier Bearing Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by THROUGHITALLDUDE, Jan 11, 2011.
What do you think
Poll closed Feb 10, 2011.
  1. Replace Carrier Bearing
    5 vote(s)
    55.6%
  2. Greasing it prob did the trick dont worry too much
    4 vote(s)
    44.4%
  1. Jan 11, 2011 at 2:41 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE [OP] Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    Ok so about a week ago did a tranny flush everything went great.....but last night my GF noticed that in reverse my truck would squeak really bad and it was only in reverse....so I went under and lubed up my leaf springs figuring they were like the problem like always but they werent. Then the sound starting sound like my rear tires were rubbing something, but they werent. So I than grabbed the WD40 to try and locate the problem well i sprayed the carrier bearing drove around in reverse and after a little bit it went away. So i drove home and it came back bc i only use WD40 and just right now I used some grease around the carrier bearing U joint and had to drive it around in reverse and it finally went away.
    My question is....Is my Carrier bearing blown or do they sometimes need to be lubed up?.....Also if greasing is fine is what I did to it ok or is there another alternative?
  2. Jan 11, 2011 at 2:55 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
  3. Jan 11, 2011 at 3:01 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I show 14 minutes since the original post. Patience grasshopper!
  4. Jan 11, 2011 at 3:06 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    lol my bad this is just kinda freaking me out cause it came out of nowhere
  5. Jan 11, 2011 at 3:08 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    :laugh: Bump
  6. Jan 11, 2011 at 3:53 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    :mad: :p
  7. Jan 11, 2011 at 10:33 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    Update: so earlier I put grease on my finger and just rubbed it around the carrier bearing and where the shaft mean. The noise is gone . I do have a little play in the shaft but that is normal play.... so I dont know what the next step is but its totally silent now..l also I was under the truck and could not find a damn ZERK for the life of me I saw the little pins that are on the ends of the shafts do I have to take those out to find the zerks????
  8. Jan 11, 2011 at 10:50 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    lets see if this picture gets more views for my questions lol
  9. Jan 11, 2011 at 10:56 PM
    daftcon
    daftcon too many clowns, not enough circuses.
    François Dillinger
    places
    '05 PreRunner
    just about black everything. i don't dig the chrome.
    ^^ HAHA it worked for me, however i skipped right down to the picture instead of reading your post.
  10. Jan 11, 2011 at 10:56 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    aagghh you dragged me in, lol. I'm not sure what you should do I just wanted to see the pic.
  11. Jan 11, 2011 at 10:58 PM
    Manwithoutaplan
    ID
  12. Jan 11, 2011 at 11:13 PM
    MadTaco461
    MadTaco461 BRO runner
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
    Those are some epic boobs. ohh yeah carrier bearing, um boobs are better. Well they don't have a zerk. You can tell if they are bad if you get a vibration in your drive train.
  13. Jan 11, 2011 at 11:13 PM
    TacoRun
    TacoRun Subd for later..
    Luis
    Edinburg,Texas
    TRD off road, Magnetic Gray
    Pop Lock, Ranch Hand brush guard
  14. Jan 11, 2011 at 11:16 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What was the question , I saw the titties on the home page
  15. Jan 11, 2011 at 11:20 PM
    MadTaco461
    Murrieta, CA
    Kinda stock
    I'd replace it if the grease did shut it up cuz it is a sealed bearing. Bearing is basically going to be telling you again soon with a vibration feeling. You got 5 years out of it. Offroad and water kills them.
  16. Jan 11, 2011 at 11:21 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    no i know there is no zerks on the Carrier i thought there would be some at least somewhere on the shaft well I went back out there and Realized that where my angle was on the carrier bearing the rubber boot was being rubbed by the shaft which was rotating which was making the continuing squeak noise only in reverse because when you reverse the shaft shifts a little so I need to get a carrier drop kit to fix that angle because of my lift.
    I only put a little grease around the outside of the boot and that made that noise stop because its not longer just rubber to metal
  17. Jan 11, 2011 at 11:25 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    dude I never use punctuation outside of school. lol UCR has burnt me out and you should know that mike lol
  18. Jan 11, 2011 at 11:25 PM
    OZ-T
    Peter North
    British Columbia
    LOL
  19. Jan 11, 2011 at 11:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2
  20. Jan 12, 2011 at 7:14 AM
    sardog2111
    sardog2111 Well-Known Member
    AL
    05 silver streak DC, 5100, borla exhuast
    5100's, Volant Intake, Borla Exhaust. FJ wheels, Wet Okole's. HID's, Go Rhino Steps bars.
    I bought an aftermarket bearing from my local driveshaft place. It was 63 dollars out the door. very easy install, the 01-04 Carrier Bearing is the same according to the book. If you go to the stealership and buy one bring some of that lube for your A$$. To repalce it is not that hard if you have a buddy and some decent mechanic skills. MARK YOUR DRIVESHAFT..... it is a few hour job but can be done in the garage with basc tools.
