Carrier Bearing Issue
Discussion in 'Suspension' started by nolanspawn, Oct 18, 2009.
  1. Oct 18, 2009 at 1:50 PM
    nolanspawn
    nolanspawn [OP] Work In Progress
    Layton, Utah
    2011 Tundra Crewmax
    Corsa Exhuast, AFE Intake
    Does something look messed up in the picture. From other pictures I could find online the rubber portion is even on both sides of the bracket but on mine it appears to be pushed out towards the rear. I cant remember if before I installed my CB drop kit if it was like this. I got curious to check the tension of the bolts after how harsh of vibrations I was feeling after the install. I cant seem to push it back in between the brackets. I cant separate the top and bottom half of the bracket because it is pressed together to make it a one piece.
    Here is another guy on the forums CB for reference.
  2. Oct 18, 2009 at 8:16 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I believe it should be centered in the unit, it looks like it has dropped down for what ever reason. I would mark and undo the drive shaft and see how much play is in the bushing.
