Carrier Bearing silicone packed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boogyman, Dec 18, 2014.
  1. Dec 18, 2014 at 8:31 PM
    Boogyman
    Boogyman [OP] Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I've seen a couple threads with some guys mentioning packing the carrier bearing with silicone. i purchased a timken CB because it was dirty freaking cheap and even if it only lasts 10k miles it'll be worth it to me. but if i can pack it with silicone like some guys are mentioning and get more life into it I'm all for it. anyone personally done this or have pics??? also I'm wondering if i can pack it with grease and maybe put a zerk fitting in the drain hole and maybe that will increase the life.
  2. Dec 18, 2014 at 8:33 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Bump for more info. Sub'd
  3. Dec 18, 2014 at 8:40 PM
    el tardo
    el tardo Well-Known Member
    i can see it on the outside but not packed with it as it doesn't have any lubricating ability.
  4. Dec 18, 2014 at 8:43 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Have you considered botox?
    Butt, seriously. You talking about injecting the rubber collar with silicone?
  5. Dec 18, 2014 at 8:48 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I believe that's what they're meaning when I read through the threads.
  6. Dec 18, 2014 at 8:50 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
  7. Dec 18, 2014 at 9:40 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
  8. Dec 18, 2014 at 11:14 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't use grease... [​IMG]
    That would make quite a mess I'm sure.
  9. Dec 19, 2014 at 1:49 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    It looks like that they're filling in between the rubber boot and the metal housing. But what about filling grease inside the actual bearing. And plugging the drain hole or finding a way to put a zerk into the hole
  10. Dec 19, 2014 at 2:05 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    The first time I replaced my csb. It was a Timken. Straight out of the box. It needed replacement after 2500 miles. The second time I packed the bearing (inside the metal not the rubber) to the brim with grease. So far I have 20k on it and I just noticed a small rip in the rubber.
  11. Dec 19, 2014 at 2:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    filling the CB with silicone..... something like permatex ultra black has been on my list of things to do.
    This would have nothing to do with lubing the cb, but strengthening the SUPER soft rubber than surrounds it to reduce driveline deflection.
  12. Dec 19, 2014 at 3:13 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Yeah I know but if I could keep the bearings well lubricated and strengthen the boot id imagine it would last a looong time
  13. Dec 20, 2014 at 8:51 PM
    MTopp
    05 SR5 4x4
  14. Dec 20, 2014 at 8:52 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    :cheers:
  15. Dec 30, 2014 at 8:30 PM
    toyrolla74
    toyrolla74 Well-Known Member
    Curtis
    East Texas Origins
    09/4x4/DCLB Speedway Blue
    im prepping for the tear down of the csb and the u joints all at once. thinking about filling the boot with some sort of lube/grease possibly? what brand of csb did you guys use? and the bearings are not a sealed unit so that i could take the bearings apart and pack it with more grease before installation correct? im assuming that first and second gen tacomas all run the same because i havent seen any specification between the two
  16. Dec 31, 2014 at 7:58 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    The carrier bearings are he same on all tacomas and I found a CB on Amazon for 10 bucks and I installed it 2 days ago. I'm gonna wear it in a little then pack it with silicone. You can buy way better ones but for 10 bucks I couldn't go wrong
  17. Dec 31, 2014 at 8:15 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I'd check with timken. Bearings are finicky with lubrication. I wouldn't add something like that cause a couple of guys on tacoma world do it.
  18. Jan 7, 2015 at 5:54 PM
    MTopp
    05 SR5 4x4
    You must not know how TW works, you must do what the internet says.
    TerrapinOverland likes this.
